Transport Equation in InterFoam using MULES
Old   August 1, 2017, 16:41
Default Transport Equation in InterFoam using MULES
TCS
Thomas C. Sykes
TCS is on a distinguished road
Hi All,
OpenFOAM 4.1
I am adding a scalar transport equation to the InterFOAM solver
$\frac{\partial c}{\partial t} + \nabla\cdot(c{\bf u})$
to track the progress of a scalar concentration field (c) which I define in setFields to be 0,1,2 initially in certain locations.
I have successfully added a standard equation in the InterFoam.C file:
fvScalarMatrix CEqn
              fvm::ddt(c)
            + fvm::div(phi, c)
CEqn.solve();
However, this is affected by a large amount of numerical diffusion.
I understand I need to use the MULES FCT scheme to try and solve this, as noted in Using MULES to solve transport equation with sharp interface but am unsure of how to do this.
I've tried adding the following to the alphaEqn file:
        tmp<surfaceScalarField> phiCure
            fvc::flux
                phi,
                c,
                alphaScheme
          + fvc::flux
               -fvc::flux(-phir, alpha2, alpharScheme),
                c,
                alpharScheme
together with
MULES::explicitSolve(c, phiCN, phiCure, 2, 0);
but this does not compile with wmake:
error: no matching function for call to ‘explicitSolve(Foam::volScalarField&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, int, int)’
among many errors.
Any help appreciated! Cheers.
TCS is offline   Reply With Quote
Old   August 7, 2017, 16:18
TCS
Thomas C. Sykes
Any help appreciated.
Old   August 7, 2017, 18:48
Cyp
Cyprien
Cyp is on a distinguished road
If you just advect a passive scalar without particular condition at the interfaces, why not just solve C from alpha? In your case you just have C=alpha.
Cheers,
Cyp is offline   Reply With Quote
Old   August 10, 2017, 22:12
TCS
Thomas C. Sykes
Cheers,
Hi, I've got there regions (2 droplets coalescing) of flaid. Two have the same alpha value and the issue is I need to know where one droplet is going when it coalescea with the other. So alpha gets me the outline of the two droplets together but not of each separately if you see what I mean. Because the two droplets are (currently) the same fluid. Thanks for the suggestion though
Old   August 15, 2017, 23:08
Cyp
Cyprien
When two droplets coalesce they become one... I am not sure your problem is well posed.
Old   March 20, 2018, 11:57
Marius Bünker
Blumenkind is on a distinguished road
I am stuck with a similar problem. Have you gotten any further?
Edit: Not a similar problem though. You were trying to compile two int, when the compiler wanted to see fields...
Blumenkind is offline   Reply With Quote
interfoam, mules, programming, transport equation
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Solving Transport equation for additional variable using CFX creddy_trddc CFX 11 April 2, 2015 21:07
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Turbulent Heat Transfer Transport Equation Flo.duck Main CFD Forum 0 May 6, 2009 03:37
Poisson equation combined with transport equation Se-Hee CFX 0 December 27, 2007 01:00
