Adding Source term to MULES
Old   March 20, 2018, 08:47
Default Adding Source term to MULES
Saicharan
wavefunction is on a distinguished road
Hello to everyone reading this.
I am having trouble adding a source term in MULES. I want to modify interMixingFoam to accomodate phase change. So I want to add the source terms -mDot/rho1 to alpha1Eqn and mDot/rho2 to alpha2Eqn.
mDot = D*rhogp*mag(fvc::grad(Y))*mag(fvc::grad(alpha1))/(scalar(1) - Y)
where D - diffusion coefficient, Y - mass fraction, rhogp - gas phase density.
Without adding the source terms to MULES, my case using my custom solver is diverging immensely. On running gdb, I found that the problem lies at line 442 of MULESTemplates.C.
Please help me.
Program received signal SIGFPE, Arithmetic exception.
0x00000000004900b1 in Foam::MULES::limiter<double, Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::zeroField> (
allLambda=..., rDeltaT=@0x7fffffff4cb0: 400000000, rho=..., psi=...,
phiBD=..., phiCorr=..., Sp=..., Su=..., psiMax=1, psiMin=0)
at /home/saicharanb56/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/MULESTemplates.C:442
442 max(min
wavefunction is offline   Reply With Quote
Old   January 26, 2022, 22:08
Pavithra is on a distinguished road
I am facing the same problem. Did you have any success in solving this issue ?
Kindly please help me.
Thank You.
Pavithra is offline   Reply With Quote
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
