continuity error occurs when combining dynamicRefineFvMesh and dynamicMotionSolverFvM |
February 7, 2018, 17:30 |
SSSSS
Rep Power: 14 |
I am trying to combine dynamicRefineFvMesh and dynamicMotionSolverFvMesh with solidBody motionFunction. the new class is based on the dynamicRefineFvMesh and just adding a motionSolver pointer as follows:
class dynamicMotionRefineFvMesh : public dynamicFvMesh { protected: ... //- motion solver autoPtr<motionSolver> motionPtr_; ... } Code:
bool Foam::dynamicMotionRefineFvMesh::update() { fvMesh::movePoints(motionPtr_->newPoints()); if (foundObject<volVectorField>("U")) { lookupObjectRef<volVectorField>("U").correctBoundaryConditions(); } ... } Code:
dynamicFvMesh dynamicMotionRefineFvMesh; motionSolver solidBody; solidBodyMotionFunction tabulated6DoFMotion; CofG (0 0 0); timeDataFileName "constant/6DoF.dat"; refineInterval 1; field alpha.water; lowerRefineLevel 0.001; upperRefineLevel 0.999; unrefineLevel 10; nBufferLayers 1; maxRefinement 2; maxCells 200000; correctFluxes ( (phi none) (nHatf none) (rhoPhi none) (alphaPhi none) (alphaPhi10 none) (ghf none) ); dumpLevel true; Code:
--> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1e-300 Specified mass inflow : 3770.92 Specified mass outflow : 3770.92 Adjustable mass outflow : 0 Code:
Total flux : 123172. Specified mass inflow : 389e-13 Specified mass outflow : 389e-13 Adjustable mass outflow : 0 |
March 29, 2018, 11:20 |
Fabian
Did you find a solution for this problem? I merged dynamicRefineFvMesh and dynamicMotionSolverFvMesh in a quite similar way which leads to the same error. I tried to solve it by adjusting the parameters of the PIMPLE algorithm (especially changing correctingPhi to "yes") which reduces the total Flux but not in a satisfactory way.
I am not sure if it has anything to do with the boundary field because even if my refinement should be performed in the middle of the domain the error occurs. If I choose settings so that no cells are refined the dynamic mesh works fine exactly like dynamicMotionSolverFvMesh. |
April 5, 2018, 04:42 |
Temporary solution found
Fabian
I overcame this error relatively simple by changing the correctPhi parameter in the PIMPLE subdictionary of fvSolution to no. Unfortunately I do not have results to check the effects until now because another error occurs which I plan to discuss in detail in a new thread.
Combining mesh motion and refinement | mturcios777 | OpenFOAM Programming & Development | 15 | September 16, 2022 01:04 |
dynamicRefineFvMesh problem | Petr Kazarin | OpenFOAM Running, Solving & CFD | 5 | November 9, 2017 06:36 |
Does dynamicRefineFvMesh work with unstructured tetra meshes? | giovanni.medici | OpenFOAM Running, Solving & CFD | 2 | August 23, 2017 02:35 |
Crash with interDyMFoam + dynamicRefineFvMesh + 64procs | RobertoRibeiro | OpenFOAM Bugs | 1 | April 10, 2017 11:11 |
Simulation crash with dynamicRefineFvMesh and kOmegaSST - OF 2.3.x | nathanael | OpenFOAM Running, Solving & CFD | 4 | June 29, 2014 17:02 |
