BL k-ε-v2/k model implementation - OpenFOAM 4 |
April 20, 2018, 04:09 |
Tomek
Dear all,
for some time already I struggle a lot with trial to implement the turbulence model from the title. Basing on those two sources: https://pingpong.chalmers.se/public/...ml?language=sv http://www.tfd.chalmers.se/~hani/kur...esentation.pdf and of course original model: A robust k − ε − v2/k elliptic blending turbulence model with improved predictions in near-wall, separated and buoyant flows I based my files on original v2-f (that's the reason for unchanged variables k,e,v2,f). I was able to write and compile it, however turbulence kinetic energy results obtained even with the flat channel flow are wrong. In the attachments, I inlclude all the files, including wall function for modified epsilon. Therefore my question is, has anyone succefully implemented the same model? Or maybe someone can identify, what I am doing wrong. Maybe I shouldn't base it on original v2-f? Last edited by tomaszkura; April 24, 2018 at 09:40. |
April 27, 2018, 03:20 |
Rep Power: 9 |
Hi
I guess you forgot to attach the files ... |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Simulating an aether model of EM using OpenFoam? | lamare | Electromagnetics | 2 | September 15, 2016 05:08 |
Adding a custom turbulence model in OpenFOAM 3.0 | Sylvain | OpenFOAM Programming & Development | 3 | July 18, 2016 08:15 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
