Find List of Options for given dictionary key programmatically
Old   June 29, 2018, 17:30
Default Find List of Options for given dictionary key programmatically
James Wright
u2berggeist is on a distinguished road
So I'm working on a vim plugin for OpenFOAM that will hopefully provide some completion help.
To do that, I need a list of possible options for a given dictionary key. How can I access the available options easily and programmatically?
I've found a brute force way of doing it; misname a option and the error message will show the available options:
--> FOAM FATAL IO ERROR:
Unknown ddt scheme Eulers
Valid ddt schemes are :
8
CoEuler
CrankNicolson
Euler
SLTS
backward
bounded
localEuler
steadyState
While this works, I was wondering if there was a way to get it a bit more directly.
The way I see it, it could be done by two ways: either go through OpenFOAM to find it (ie. mangle around with C++ or use a builtin function that I don't know about) OR find out how it creates the list in the first place.
I've tried looking at the source code (look at "OpenFOAM/OpenFOAM-v1712/src/finiteVolume/lnInclude/ddtScheme.C" at line 76 for the code that created the output of the above example), but I have no experience in C++ (or any statically typed language for that matter) and have had a very difficult time figuring it out.
Any help would be greatly appreciated!
u2berggeist is offline   Reply With Quote
Old   July 3, 2018, 12:32
James Wright
Update on the "How do they know whether an option is available?" problem; The list that is output through the error message comes from a runTimeSelectionTable.
Now my question turns to how can I access said runTimeSelectionTable?
dictionary, openfoam, options
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
