wmake error in openfoam 6
Old   July 23, 2018, 17:25
Default wmake error in openfoam 6
Cleiton Luiz
CtnLuiz is on a distinguished road
Hello everyone!
I'm trying to run the tutotial How_to_add_transport_of_N_solutes_to_icoFoam in openfoam 6 and I can not solve the following error
:~/OpenFOAM/claiton-6/run/transportIcoFoamN# wmake
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam6/src/finiteVolume/lnInclude -I/opt/openfoam6/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude -fPIC -c transportIcoFoamN.C -o Make/linux64GccDPInt32Opt/transportIcoFoamN.o
transportIcoFoamN.C:33:41: fatal error: basicMultiComponentSolution.H: Arquivo ou diretório não encontrado
#include "basicMultiComponentSolution.H"
compilation terminated.
make: ** [Make/linux64GccDPInt32Opt/transportIcoFoamN.o] Erro 1
Could someone help me with this?
CtnLuiz is offline   Reply With Quote
Old   July 24, 2018, 12:48
Cleiton Luiz
Originally Posted by CtnLuiz View Post
Hello everyone!
Comparing the transportIcoFoamN.C file of the tutorial with the OpenFoam icoFoam.C file I noticed that the "PISO loop" is written differently, but I think it is not enough just to copy and paste, anyway I do not know how to change it.
Application transportIcoFoamN
Description
Transient solver for incompressible, laminar flow of Newtonian fluids.
#include "fvCFD.H"
#include "solute.H"
#include "PtrDictionary.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "readPISOControls.H"
#include "CourantNo.H"
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p));
// --- PISO loop
for (int corr=0; corr<nCorr; corr++)
volScalarField rAU(1.0/UEqn.A());
U = rAU*UEqn.H();
phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rAU, U, phi);
adjustPhi(phi, U, p);
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
#include "continuityErrs.H"
Application icoFoam
Description
#include "fvCFD.H"
#include "pisoControl.H"
#include "setRootCaseLists.H"
pisoControl piso(mesh);
// Momentum predictor
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
if (piso.momentumPredictor())
// --- PISO loop
while (piso.correct())
volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
surfaceScalarField phiHbyA
"phiHbyA",
fvc::flux(HbyA)
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
adjustPhi(phiHbyA, U, p);
// Update the pressure BCs to ensure flux consistency
constrainPressure(p, U, phiHbyA, rAU);
// Non-orthogonal pressure corrector loop
while (piso.correctNonOrthogonal())
// Pressure corrector
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.solve(mesh.solver(p.select(piso.finalInnerIte r())));
if (piso.finalNonOrthogonalIter())
phi = phiHbyA - pEqn.flux();
openfoam6, wmake error
[OpenFOAM.org] wmake problem vville OpenFOAM Installation 1 October 8, 2015 05:01
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
OpenFoam wmake not found CTR OpenFOAM Installation 2 April 27, 2014 06:10
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
