List of chemical species from a boundary condition |
benoit favier
Rep Power: 8 ![]() |
I am coding a new boundary condition in OpenFoam 6. This boundary condition is to be used with the "reactingFoam" solver. I want to acces the list of chemical species defined from this boundary condition. I can access the mass fraction of a single specie using : Code:
const Foam::fvPatchField<scalar>& W_N2 = this->patch().lookupPatchField<volScalarField, scalar>("N2"); Code:
const PtrList<volScalarField>& Y = thermo.composition().Y(); Is there anyway to get access to it from the boundary condition ? Last edited by Benben; August 31, 2018 at 05:35. |
Yan Zhang
Rep Power: 12 ![]() |
Maybe you can get thermo by lookupObject?
benoit favier
Hello, thank you for your interest in my problem.
It seems like it worked. To create a "psiReactionThermo" object (which is the type of thermo), i have to include "psiReactionThermo.H" in my boundary condition header file, and add the lines : Code:
-I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \ -I$(LIB_SRC)/ODE/lnInclude \ -I$(LIB_SRC)/combustionModels/lnInclude Then in the code of my boundary condition, i add : Code:
const psiReactionThermo& thermo = this->db().lookupObject<psiReactionThermo>("thermophysicalProperties"); const PtrList<volScalarField>& Y = thermo.composition().Y(); However i have no clue on why i have access to it from the "ObjectRegistry". I am not very familiar with this class. In the declaration of "thermo", nothing is done to add it to a registry. What other variables do we have access to from there ? every variable created ? Last edited by Benben; August 31, 2018 at 04:19. Reason: error in the code |
Yan Zhang
https://openfoam.top/en/thermodynamicLIB/
You can have a look at this UML, and you'll find that IOdictionary is the topmost base class of psiReactionThermo. Since IOdictionary is often registried to the mesh, so will psiReactionThermo. |
benoit favier
I have another issue :
when calling Code:
thermo.composition() Code:
pure virtual method called ![]() How should i proceed to get the composition object ? |
benoit favier
It's probable that i should define it as an "hePsiThermo" (documentation here) as this is what i am asking openfoam to use in my dictionnary in "constant/thermophysicalProperties":
thermoType { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } |
benoit favier
"hePsiThermo" takes two templates class, and i can't manage to declare a instance of the class :/
i Tried : Code:
const hePsiThermo<psiReactionThermo, reactingMixture<psiReactionThermo>>& thermo = this->db().lookupObject<hePsiThermo<psiReactionThermo, reactingMixture<psiReactionThermo>>("t"); Code:
/opt/openfoam6/src/thermophysicalModels/reactionThermo/lnInclude/multiComponentMixture.H:61:28: error: cannot declare field 'Foam::multiComponentMixture<Foam::psiReactionThermo>::mixture_' to be of abstract type 'Foam::psiReactionThermo' mutable ThermoType mixture_; ^ In file included from evaporatingZinc_RDMP/evaporatingZinc_RDMPFvPatchScalarField.H:81:0, from evaporatingZinc_RDMP/evaporatingZinc_RDMPFvPatchScalarField.C:26: /opt/openfoam6/src/thermophysicalModels/reactionThermo/lnInclude/psiReactionThermo.H:52:7: note: because the following virtual functions are pure within 'Foam::psiReactionThermo': class psiReactionThermo |
Yan Zhang
Try this?
const PtrList<volScalarField>& Y = dynamic_cast<hePsiThermo<psiReactionThermo,SpecieMixture<reactingMixture<gasHThermoPhysics>>>&> (this->db().lookupObject<psiReactionThermo>("thermo")).composition().Y(); |
#9 |
benoit favier
I tried as you proposed :
const psiReactionThermo& hepsi_thermo = this->db().lookupObject<psiReactionThermo>("thermophysicalProperties"); const hePsiThermo<psiReactionThermo,SpecieMixture<reactingMixture<gasHThermoPhysics>>>& thermo = dynamic_cast<const hePsiThermo<psiReactionThermo,SpecieMixture<reactingMixture<gasHThermoPhysics>>>&>(hepsi_thermo); Code:
terminate called after throwing an instance of 'std::bad_cast' what(): std::bad_cast How did you know what types should be used for the cast ? In the code I only found the definition of "thermo" in "createFields.H". And it is defined as a psiReactionThermo : Code:
autoPtr<psiReactionThermo> pThermo(psiReactionThermo::New(mesh)); psiReactionThermo& thermo = pThermo(); |
#10 |
benoit favier
I tried by cheating with pointers :
const psiReactionThermo& hepsi_thermo = this->db().lookupObject<psiReactionThermo>("thermophysicalProperties"); hePsiThermo<psiReactionThermo,SpecieMixture<reactingMixture<gasHThermoPhysics>>> * thermo = & hepsi_thermo; Code:
error: cannot convert 'const Foam::psiReactionThermo*' to 'Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >*' in initialization hePsiThermo<psiReactionThermo,SpecieMixture<reactingMixture<gasHThermoPhysics>>> * thermo = & hepsi_thermo; |
#11 |
benoit favier
I managed to solve my problem.
The right way to do it was to define Code:
#include "psiReactionThermo.H" const psiReactionThermo& thermo = this->db().lookupObject<psiReactionThermo>("thermophysicalProperties"); const PtrList<volScalarField>& Y = thermo.composition().Y(); Code:
-I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude However, the first call of the boundary conditions is made when thermo is beeing built (as mass fractions, rho, and T are initialized by thermo). So, when the boundary condition is called for the first time, thermo is not completly initialized yet. So i had to implement a bypass so that the first call to the boundary condition initializes to some garbage, and doesnt call "thermo.composition()". The boundary condition is still updated before solving the first time step, so no problem for the resolution (i verified this by outputing some text in the console). The only thing is that paraFoam will show some garbage for the boundary condition at time t=0. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
