September 27, 2018, 00:20 |
wmake error: command not found
Ishan Anjikar
Rep Power: 8 |
Hi
I am trying to make a new solver and followed the steps mentioned here: https://www.cfdsupport.com/OpenFOAM-...t/node187.html The folder mentioned in the $WM_PROJECT_USER_DIR was not present initially, so i made the folder. I have attached the sequence of commands i used. I am getting the error for wmake command. I have tried to compile on OpenFOAM-v1706, OpenFOAM-v1712 and OpenFOAM-1806 Please help me solve this error. If i am doing something wrong, please guide me on how to correct it. Thank you. |
September 28, 2018, 15:10 |
Chen Shen
Rep Power: 7 |
ianjikar@LAPTOP-0DDG57S0:~/OpenFOAM/ianjikar-v1806/applications/solvers/icoTempFoam$ wmake
/opt/OpenFOAM/OpenFOAM-v1806/wmake/wmake: line 409: make: command not found /opt/OpenFOAM/OpenFOAM-v1806/wmake/wmake: line 412: make: command not found Under the hood, wmake call make to do stuffs. GNU make :https://www.gnu.org/software/make/ I think the answer is simple: Install make to do it on ubuntu: 1. sudo apt-get install make if 1 does not work: 2. sudo apt-get install build-essential if 1 and 2 does not work: 3. sudo apt-get install --reinstall make Tell me if it does not solve your problem. Chen |
September 30, 2018, 19:24 |
#3 | |
Ishan Anjikar
Rep Power: 8 |
Thanks for replying. The option 1 did work. But when i try to compile a solver, i got the following error: Making dependency list for source file icoTempFoam.C g++ -std=c++11 -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/OSspecific/POSIX/lnInclude -fPIC -c icoTempFoam.C -o Make/linux64Gcc63DPInt32Opt/icoTempFoam.o In file included from /opt/OpenFOAM/ThirdParty-v1806/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/c++config.h:507:0, from /opt/OpenFOAM/ThirdParty-v1806/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/cstdint:38, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/int16.H:38, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/int.H:38, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/label.H:39, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/labelList.H:59, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/UPstream.H:42, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/Pstream.H:42, from /opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude/parRun.H:38, from /opt/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude/fvCFD.H:4, from icoTempFoam.C:63: /opt/OpenFOAM/ThirdParty-v1806/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory #include <features.h> ^ compilation terminated. /opt/OpenFOAM/OpenFOAM-v1806/wmake/rules/General/transform:34: recipe for target 'Make/linux64Gcc63DPInt32Opt/icoTempFoam.o' failed make: *** [Make/linux64Gcc63DPInt32Opt/icoTempFoam.o] Error 1 And then i used option 2 and i got the following error when using wmake: g++ -std=c++11 -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/OSspecific/POSIX/lnInclude -fPIC -c icoTempFoam.C -o Make/linux64Gcc63DPInt32Opt/icoTempFoam.o g++ -std=c++11 -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc63DPInt32Opt/icoTempFoam.o -L/opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64Gcc63DPInt32Opt/lib \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl \ -lm -o /home/ianjikar/OpenFOAM/ianjikar-v1806/platforms/linux64Gcc63DPInt32Opt/bin/icoTempFoam I am not sure what is happening. Thanks in advance for helping |
October 1, 2018, 18:13 |
#4 | |
Chen Shen
Rep Power: 7 |
Since you installed make, then the wmake is actually trying to compile the source code.
It terminated because it cannot fine a header file called "features.h". On my laptop, features.h is located at usr/include/ . However, your compiler seems cannot find it in the default search path. It may suggest a incomplete build of the compiler. That means installing a compiler alone is not sufficient, you need headers and libraries too. Then I think you have tried the command "sudo apt-get install build-essential". which will fix the incomplete build of g++. So I think it should be OK now and Quote:
So when you copy the solver folder, there is a folder in it called Make. In the Make/, there is a file called "files". you also need to modify the line EXE=................ in the Make/files in mine, it says: icoFoam.C EXE = /home/chen/OpenFOAM/chen-6/run/icoFoam/icoFoam which means, wmake need a file called icoFoam.C and the output is /home/chen/OpenFOAM/chen-6/run/icoFoam/icoFoam. In your case, you can try to modify it as : EXE =~/Desktop/icoTempFoam and run wmake again. If you can find icoTempFoam in the Desktop, that means you have built it successfully. Tell me if it does not solve your problem. Chen |
October 2, 2018, 00:31 |
#5 | |
Ishan Anjikar
Rep Power: 8 |
icoTempFoam.C EXE = /home/ianjikar/OpenFOAM/ianjikar-v1806/applications/solvers/icoTempFoam Then i ran the wmake command and got the following error: g++ -std=c++11 -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1806/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc63DPInt32Opt/icoTempFoam.o -L/opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64Gcc63DPInt32Opt/lib \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl \ -lm -o /home/ianjikar/OpenFOAM/ianjikar-v1806/applications/solvers/icoTempFoam /usr/bin/ld: cannot open output file /home/ianjikar/OpenFOAM/ianjikar-v1806/applications/solvers/icoTempFoam: Is a directory collect2: error: ld returned 1 exit status /opt/OpenFOAM/OpenFOAM-v1806/wmake/makefiles/general:136: recipe for target '/home/ianjikar/OpenFOAM/ianjikar-v1806/applications/solvers/icoTempFoam' failed make: *** [/home/ianjikar/OpenFOAM/ianjikar-v1806/applications/solvers/icoTempFoam] Error 1 I have attached a photo of the directory path for help |
October 2, 2018, 03:42 |
Vince
Rep Power: 9 |
You need to add the name of the executable, which seems to be the same as your directory. The Make/files becomes: icoTempFoam.C EXE = $(FOAM_USER_APPBIN)/icoTempFoam Cheers, Vincent |
October 2, 2018, 11:44 |
Ishan Anjikar
Rep Power: 8 |
Hi Vincent,
Initially the EXE was as you mentioned, but when i called the $FOAM_USER_APPBIN variable, the path was: /home/ianjikar/OpenFOAM/ianjikar-v1806/platforms/linux64Gcc63DPInt32Opt/bin/ So i changed the path to where icoTempFoam.C is present and tried compiling if thats the problem Thanks for looking into it Regards Ishan |
October 2, 2018, 15:25 |
Cyrille Bonamy
Rep Power: 11 |
The EXE directory is the directory where the final binary is compiled, but it is not related to the directory where the sources are.
In your case, the source (icoTempFoam.C) must be in the directory where there is the Make directory. And so you just have to type "wmake" in this source directory in order to compile and place the binary at the EXE location. |
October 7, 2018, 04:21 |
#9 | |
Ishan Anjikar
Rep Power: 8 |
January 20, 2019, 17:03 |
Zacarias Carral
Dear people,
I have the same error about features.h: No such file or directory. I have tried the 3 procedures and I always have the same error about features.h: No such file or directory: 1. sudo apt-get install make if 1 does not work: 2. sudo apt-get install build-essential if 1 and 2 does not work: 3. sudo apt-get install --reinstall make My make/files is: solvername.C EXE = $(FOAM_USER_APPBIN)/solvername I have OpenFOAM 1812 installed on Windows 10. |
January 23, 2019, 11:42 |
#11 |
Zacarias Carral
Dear everybody,
Finally I found the solution in this forum: https://www.cfd-online.com/Forums/op...oam-1712-a.htm I executed the following commands and then my solver compiled: sudo apt update sudo apt install build-essential flex bison |
December 29, 2019, 16:17 |
internal compiler error: Illegal instruction constexpr floatScalar floatScalarGREAT
#12 |
Eduard Englberth
Hello everybody!
I am trying to compile my own solver called vsFoam. That solver is based on simpleFoam solver. The openFoam version is 1906. I am compiling it on Ubuntu 18.04 LTS application of Windows 10. I have made following commands sudo apt update sudo apt install build-essential flex bison sudo apt-get install make However, wmake still returns error. Plese see bellow. Can anybody help me so solve that issue? root@DESKTOP-OMKC5MD:/opt/OpenFOAM/OpenFOAM-v1906/applications/solvers/incompressible/vsFoam# ls Make UEqn.H createFields.H pEqn.H vsFoam.C root@DESKTOP-OMKC5MD:/opt/OpenFOAM/OpenFOAM-v1906/applications/solvers/incompressible/vsFoam# wclean root@DESKTOP-OMKC5MD:/opt/OpenFOAM/OpenFOAM-v1906/applications/solvers/incompressible/vsFoam# wmake Making dependency list for source file vsFoam.C g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/sampling/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/TurbulenceModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/transportModels -I/opt/OpenFOAM/OpenFOAM-v1906/src/transportModels/incompressible/singlePhaseTransportModel -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c vsFoam.C -o /opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/incompressible/vsFoam/vsFoam.o In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/scalar.H:41:0, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/zeroI.H:29, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/zero.H:148, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/UList.H:50, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/List.H:45, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/labelList.H:44, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/UPstream.H:44, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/Pstream.H:44, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/parRun.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/fvCFD.H:4, from vsFoam.C:66: /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/floatScalar.H:56:1: internal compiler error: Illegal instruction constexpr floatScalar floatScalarGREAT = 1.0e+6; ^~~~~~~~~ 0xac5ddf crash_signal /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/toplev.c:333 0xa3b54d real_from_string(real_value*, char const*) /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/real.c:2107 0xa3bf9b real_from_string3(real_value*, char const*, format_helper) /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/real.c:2173 0x73b0aa interpret_float /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/c-family/c-lex.c:882 0x73be6e c_lex_with_flags(tree_node**, unsigned int*, unsigned char*, int) /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/c-family/c-lex.c:425 0x64492e cp_lexer_get_preprocessor_token /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/cp/parser.c:792 0x674b3d cp_lexer_new_main /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/cp/parser.c:656 0x674b3d cp_parser_new /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/cp/parser.c:3689 0x674b3d c_parse_file() /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/cp/parser.c:37538 0x741702 c_common_parse_file() /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/c-family/c-opts.c:1064 Please submit a full bug report, with preprocessed source if appropriate. Please include the complete backtrace with any bug report. See <http://gcc.gnu.org/bugs.html> for instructions. /opt/OpenFOAM/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target '/opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/incompressible/vsFoam/vsFoam.o' failed make: *** [/opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/incompressible/vsFoam/vsFoam.o] Error 1 |
December 29, 2019, 16:33 |
#13 |
Herpes Free Engineer
Rep Power: 12 |
have you installed OF? have you verified the installation?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 29, 2019, 19:23 |
#14 |
Eduard Englberth
Yes, I have installed openFoam version 1906. I am alreday doing simulation with simpleFoam solver, so it works. I would like to, however, modify simpleFoam solver for my purpose and I have problems to compile it. I have done it on Ubuntu Linux with OF 2.2.1 few years ago. Now, I am doing it on Ubuntu Linux application on Windows 10 with latest OF version. Maybe there is the problem.
December 30, 2019, 02:40 |
#15 |
Rep Power: 12 |
Could you go to the forum topic:
[OpenFOAM.com] v1712 GCC 6.3.0 - internal compiler error: Illegal instruction where Bruno Santos gave insights. (Sorry, I couldnt manage to share the link directly by using my phone.)
December 30, 2019, 10:50 |
#16 |
Eduard Englberth
As Bruno Santos advices I have checked if there is a hardware problem. I have done it with command
stressapptest -W --cc_test -M 4000 The test gave me PASS status, hardware is OK. I guess the issue has something common with GCC 6.3.0. In the thread 1712 GCC 6.3.0 - internal compiler error: Illegal instruction there is no soulution available, so I wonder if someone solved it yet. |
December 30, 2019, 17:29 |
#17 |
Rep Power: 12 |
Can you use another compiler? e.g. Clang?
December 31, 2019, 05:06 |
#18 |
Eduard Englberth
It is good idea. Do you think if it is OK to have gcc and Clang installed beside eachother? Or gcc is reccomended to be uninstalled before Clang installation.
What is reccommended compiler for openFoam v1906 from your point of view. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
error in fireFoam, when running the case wallFireSpread2D | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 9 | February 1, 2018 18:45 |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
