November 18, 2018, 16:57 |
Error compiling kEpsilon model
Guilherme
Rep Power: 10 |
I'm trying to compile a kEpsilon template (https://github.com/OpenFOAM/OpenFOAM...lon/kEpsilon.C on OpenFOAM 5.x) and am encountering two errors, which are described in the link: https://paste.ubuntu.com/p/DHHHqrgcnz/ It's a bit difficult to explain my goal, but believe me, it's very important to me. When I comment the lines from 144 to 208 (kEpsilon.C), I can compile the solver avoiding ERROR 1. I can compile (avoiding the ERRO2 described in the link) the solver when I comment lines 254 and 256 (kEpsilon.C). I hope you can help me. |
November 19, 2018, 08:58 |
Michael Alletto
From you error I assume you took a kEpsilon model from versions prior to 3.0 and tried to compile it with a newer version. In the newer versions (from 3.0 on I guess) you need to write epsEqn.ref().relax();
Have a look at https://www.openfoam.com/documentati...8C_source.html |
November 19, 2018, 10:10 |
Guilherme
Rep Power: 10 |
Thanks, I was able to compile (... yes, the version is 2.4.x).
Now there is only one ERROR to solve my problem... |
November 19, 2018, 10:49 |
Michael Alletto
can you post the error in this thread?
November 19, 2018, 10:53 |
#5 | |
Guilherme
Rep Power: 10 |
Thank you very much for your attention ... it's very important to me.
November 19, 2018, 13:08 |
Michael Alletto
You have to write probably something like this->U_ instead of U_
November 19, 2018, 13:43 |
#7 | |||
Guilherme
Rep Power: 10 |
I was able to solve my problem Michael (replaces U.time().timeName(), with runTime_.timeName(),.. I hope this solution is correct.). Thank you very much.
But now I've got a new problem ... I've created a way to read an external library (it's highlighted below): Quote:
November 21, 2018, 06:08 |
#8 | ||||
Guilherme
Rep Power: 10 |
I still get the error below if you can help me...:
EDIT1: I discovered some things about the error... ... in the kEpsilon.C: Quote:
November 21, 2018, 13:06 |
Michael Alletto
probably you tried to follows the steps in tutorials how to add a new turbulence model for OF versions prior to 3.0
In this blog http://hassankassem.me/posts/newturbulencemodel/ it is described how to do it for versions from 3.0 on |
simplifiedSiwek - error in calculating the position of a coal error | guitar_love_15 | OpenFOAM Running, Solving & CFD | 0 | November 4, 2018 04:06 |
use laminar and kEpsilon model in one case openfoam | super1 | OpenFOAM Programming & Development | 0 | December 28, 2016 07:52 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
add a source term in kEpsilon model | maurice | OpenFOAM Running, Solving & CFD | 0 | May 18, 2009 07:54 |
