Dynamic Mesh Fluid/Solid
Like Tree1Likes
  • 1 Post By simrego
Old   January 22, 2019, 11:11
Default Dynamic Mesh Fluid/Solid
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
Dear Foamers
I am attaching a simple 2D geometry where only the white edge is moving/sliding in the positive x direction.
I tried the dynamicMotionSolver, I got correct motion but unusable mesh.
I shifted to foam-extend to use the topoChanger, I tried the movingBodyTopoMesh, however it seems does not work for curved edges.
May be I need to customize a topoChanger for this case. However, I want to hear your advice first.
Regards
Saleh Abuhanieh is offline   Reply With Quote
Old   January 24, 2019, 09:05
anonymous
simrego is on a distinguished road
Hi!
What if you create a cellzone around that curved edge to the top edge? And move the whole zone.
Or check the displacementLayeredMotion. It is a bit tricky to use but really powerfull.
But there can be many solutions for this problem.
Saleh Abuhanieh likes this.
simrego is offline   Reply With Quote
Old   February 3, 2019, 05:22
Saleh Abuhanieh
Originally Posted by simrego View Post
Hi!
Hi simrego,
Thanks for your reply.
The main problem is that the upper edge is not a single straight line.
Actually I think I've solved the problem using adding/removing layers modifier.
First of All I divided the geometry to upper and lower parts (two meshes). Then I've created left and right cell zones on the lower parts and I moved the area between the left, right and the interface between lower and upper regions.
I tried to use sliding interface between the two areas without success.
For solving the physics I used GGI BC for the interface.. I am running the case right now .. let see
Saleh
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 08:40
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Rotation of airfoil in a fluid domain using dynamic mesh abhisheksaraf OpenFOAM Running, Solving & CFD 0 November 14, 2015 20:35
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
