January 30, 2019, 19:32 |
points.gz files after run blockMesh
Wenming Yang
Rep Power: 7 |
Dear Foamers,
I am running a common case. Some files such as "points.gz", "owner.gz" were generated down to polyMesh in constant folder after I run blockMesh. Then when I run the solver, it shows Cannot find file "points" in directory "box/polyMesh" in times 0 down to constant Why there generated files *.gz but not the normal ones? Thank you for your answer. |
January 30, 2019, 19:43 |
#2 | |
Andrew Somorjai
Rep Power: 13 |
If you could upload your project somewhere that would narrow things do so people can see this. Also what version of OpenFOAM are you on and what system? |
January 30, 2019, 21:26 |
#3 | |
Wenming Yang
Rep Power: 7 |
Thank you for your suggestion. I found these files works well as normal ones and they are not zip files. The problem I encountered comes from my lack of operation. I used topoSet to select cells and reassign BCs. I missed the operation of splitMeshRegions. After this operation, the case works well now. |
points.gz |
exporting .trn files during the run | natalie | CFX | 2 | June 20, 2012 06:37 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Merging .pst files in parallel run | Purushothama | Siemens | 4 | July 7, 2010 22:22 |
CFX Solver to run 10 files sequentially | Raj | CFX | 8 | October 29, 2008 22:20 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
