max function in Schnerr-Sauer Cavitation File
Old   February 8, 2019, 15:39
Default max function in Schnerr-Sauer Cavitation File
dviam is on a distinguished road
I am a bit unsure that the min/max functions are working properly in the Schnerr-Sauer cavitation model. The current code reads as:
Foam::Pair<Foam::tmp<Foam::volScalarField>>
Foam::phaseChangeTwoPhaseMixtures::SchnerrSauer::mDotAlphal() const
    const volScalarField& p = alpha1_.db().lookupObject<volScalarField>("p");
    volScalarField pCoeff(this->pCoeff(p));
    volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1)));
    return Pair<tmp<volScalarField>>
        Cc_*limitedAlpha1*pCoeff*max(p - pSat(), p0_),
        Cv_*(1.0 + alphaNuc() - limitedAlpha1)*pCoeff*min(p - pSat(), p0_)
It should be noted that p0_ is simply the scalar 0. Consider the case where p-pSat() > 0. This means that the first term in the pair Cc_*.... should have a non-zero value while the second term Cv_*.... should have a value of zero. It should be the case that these pairs never have both non-zero values at the same time. This is, however, not the case. Writing the pair to disk shows that there are instances where both values in the pair have non-zero ideas.
Any ideas how this can be corrected? Or am I interpreting the code incorrectly.
Thanks
dviam is offline   Reply With Quote
cavitation, openfoam, schnerr-sauer
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
