parabolic velocity for non-Newtonian fluid
Old   February 9, 2019, 01:40
Default parabolic velocity for non-Newtonian fluid
Hojatollah Gholami
Hgholami is on a distinguished road
Dear All
I want to modify the boundary condition of OF4.0 for using parabolic velocity for non-Newtonian fluid
the equation is : U_mean*(3*n+1)/(n+1)*(1-pow(ABS(y/(0.5*H)),(n+1)/n))
where n is fluid index and H is height of channel.
I use this code for transitionalParabolicNonVelocityFvPatchVectorField .C
HTML Code:
  \\      /  F ield         | foam-extend: Open Source CFD
   \\    /   O peration     | Version:     4.0
    \\  /    A nd           | Web:         http://www.foam-extend.org
     \\/     M anipulation  | For copyright notice see file Copyright
License
    This file is part of foam-extend.
    foam-extend is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by the
    Free Software Foundation, either version 3 of the License, or (at your
    option) any later version.
    foam-extend is distributed in the hope that it will be useful, but
    WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with foam-extend.  If not, see <http://www.gnu.org/licenses/>.
#include "transitionalParabolicNonVelocityFvPatchVectorField.H"
#include "addToRunTimeSelectionTable.H"
#include "fvPatchFieldMapper.H"
#include "volFields.H"
#include "surfaceFields.H"
namespace Foam
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
transitionalParabolicNonVelocityFvPatchVectorField::
    const fvPatch& p,
    const DimensionedField<vector, volMesh>& iF
    fixedValueFvPatchVectorField(p, iF),
    meanValue_(0),
    d_(1, 0, 0),
    y_(0, 1, 0),
    n_(0);
    transitionPeriod_(SMALL),
    boundBoxMin_(0, 0, 0),
    boundBoxMax_(0, 0, 0)
    const ParabolicNonVelocityFvPatchVectorField& ptf,
    const fvPatch& p,
    const DimensionedField<vector, volMesh>& iF,
    const fvPatchFieldMapper& mapper
    fixedValueFvPatchVectorField(ptf, p, iF, mapper),
    meanValue_(ptf.meanValue_),
    d_(ptf.d_),
    y_(ptf.y_),
    n_(ptf.n_),
    transitionPeriod_(ptf.transitionPeriod_),
    boundBoxMin_(ptf.boundBoxMin_),
    boundBoxMax_(ptf.boundBoxMax_)
    const fvPatch& p,
    const dictionary& dict
    meanValue_(readScalar(dict.lookup("meanValue"))),
    n_(readScalar(dict.lookup("n"))),
    d_(dict.lookup("d")),
    y_(dict.lookup("y")),
    transitionPeriod_(readScalar(dict.lookup("transitionPeriod"))),
    boundBoxMin_(dict.lookup("boundBoxMin")),
    boundBoxMax_(dict.lookup("boundBoxMax"))
    if (mag(d_) < SMALL || mag(y_) < SMALL)
        FatalErrorIn("transitionalParabolicNonVelocityFvPatchVectorField(dict)")
            << "d or y given with zero size not correct"
            << abort(FatalError);
    d_ /= mag(d_);
    y_ /= mag(y_);
    if (transitionPeriod_ < SMALL)
        transitionPeriod_ = SMALL;
    evaluate();
    const transitionalParabolicNonVelocityFvPatchVectorField& fcvpvf,
    fixedValueFvPatchVectorField(fcvpvf, iF),
    meanValue_(fcvpvf.meanValue_),
    n_(fcvpvf.n_),
    d_(fcvpvf.d_),
    y_(fcvpvf.y_),
    transitionPeriod_(fcvpvf.transitionPeriod_),
    boundBoxMin_(fcvpvf.boundBoxMin_),
    boundBoxMax_(fcvpvf.boundBoxMax_)
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void transitionalParabolicNonVelocityFvPatchVectorField::updateCoeffs()
    if (updated())
        return;
    scalar curMeanValue = meanValue_;
    if (this->db().time().value() < transitionPeriod_)
        scalar t = this->db().time().value();
        curMeanValue *= 0.5*(1.0-cos(M_PI*t/transitionPeriod_));
    // Get range and orientation
//    boundBox bb(patch().patch().localPoints(), true);
    vector ctr = 0.5*(boundBoxMax_ + boundBoxMin_);
    const vectorField& c = patch().Cf();
    // Calculate local 1-D coordinate for the parabolic profile
    scalarField coord = 2*((c - ctr) & y_)/((boundBoxMax_ - boundBoxMin_) & y_);
    vectorField::operator=(d_*curMeanValue*(1.0+3.0*n_)/(1.0+n_)*(1.0 - pow (coord, (1+n_)/n_)));
// Write
void transitionalParabolicNonVelocityFvPatchVectorField::write(Ostream& os) const
    fvPatchVectorField::write(os);
    os.writeKeyword("meanValue")
        << meanValue_ << token::END_STATEMENT << nl;
    os.writeKeyword("n")
        << n_ << token::END_STATEMENT << nl;
    os.writeKeyword("d")
        << d_ << token::END_STATEMENT << nl;
    os.writeKeyword("y")
        << y_ << token::END_STATEMENT << nl;
    os.writeKeyword("transitionPeriod")
        << transitionPeriod_ << token::END_STATEMENT << nl;
    os.writeKeyword("boundBoxMin")
        << boundBoxMin_ << token::END_STATEMENT << nl;
    os.writeKeyword("boundBoxMax")
        << boundBoxMax_ << token::END_STATEMENT << nl;
    writeEntry("value", os);
makePatchTypeField(fvPatchVectorField,
} // End namespace Foam
and for transitionalParabolicNonVelocityFvPatchVectorField .H
HTML Code:
License
Class
Description
    Boundary condition specifies a parabolic velocity inlet profile
    (fixed value), given maximum velocity value (peak of the parabola),
    flow direction n and direction of the parabolic coordinate y
SourceFiles
    transitionalParabolicNonVelocityFvPatchVectorField.C
Author
    Hrvoje Jasak, Wikki Ltd.  All rights reserved
#ifndef transitionalParabolicNonVelocityFvPatchVectorField_H
#define transitionalParabolicNonVelocityFvPatchVectorField_H
#include "fvPatchFields.H"
#include "fixedValueFvPatchFields.H"
namespace Foam
              Class ParabolicNonVelocityFvPatchField Declaration
class transitionalParabolicNonVelocityFvPatchVectorField
    public fixedValueFvPatchVectorField
    // Private data
        //- mean velocity magnitude
        scalar meanValue_;
        //- Fluid index
        vector n_;
        //- Flow direction
        vector d_;
        //- Direction of the y-coordinate
        vector y_;
        //- Transition period
        scalar transitionPeriod_;
        //- Bound box min (must be specified duo to bug in parallel run)
        vector boundBoxMin_;
        //- Bound box max (must be specified duo to bug in parallel run)
        vector boundBoxMax_;
public:
    //- Runtime type information
    TypeName("transitionalParabolicNonVelocity");
    // Constructors
        //- Construct from patch and internal field
            const fvPatch&,
        //- Construct from patch, internal field and dictionary
            const fvPatch&,
            const DimensionedField<vector, volMesh>&,
            const dictionary&
        //- Construct by mapping given
        //  transitionalParabolicNonVelocityFvPatchVectorField
        //  onto a new patch
            const transitionalParabolicNonVelocityFvPatchVectorField&,
            const fvPatch&,
        //- Construct and return a clone
        virtual tmp<fvPatchVectorField> clone() const
            return tmp<fvPatchVectorField>
                new transitionalParabolicNonVelocityFvPatchVectorField(*this)
        //- Construct as copy setting internal field reference
        //- Construct and return a clone setting internal field reference
        ) const
                new transitionalParabolicNonVelocityFvPatchVectorField(*this, iF)
    // Member functions
        //- Return mean value
        scalar& meanValue()
            return meanValue_;
        //- Return fluid index
        scalar& n()
            return n_;
        //- Return flow direction
        vector& d()
            return d_;
        //- Return y direction
        vector& y()
            return y_;
        //- Update coefficients
        virtual void updateCoeffs();
        //- Write
        virtual void write(Ostream&) const;
#endif
Hgholami is offline   Reply With Quote
Old   February 9, 2019, 01:44
Hojatollah Gholami
I compile the code but have several error, anyone can help me with this problem?
boundary condition, non-newtonian fluid, parabolic velocity
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Average Rising Velocity as boundary condition Floing CFX 11 August 21, 2016 05:47
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
