Implementation of thermophysical Properties in Fluid-Structure Interaction
Old   February 20, 2019, 04:15
Default Implementation of thermophysical Properties in Fluid-Structure Interaction
Marcel Neu
Marcel_pmd is on a distinguished road
Hey everyone,
I have a very basic Problem with the implementation of the thermophysical properties library to the FSI pack of foamExtend 4.0.
In general I want to write a compressible FSI solver to work with some high pressure fluid Models I found in literature. Therefore I implemented these models into the thermophysical Properties library and got them to work correctly in OF 50 with some regular cases of rhopiso and rhosimple Foam.
In the next step I wanted to implement one of the compressible solvers I used ( like rhopiso or rhosimple) to the FSI package in FE40. To do so I need to make the thermophysical model library available to the solver.
As soon as I implement the lines
//- Thermophysical model
autoPtr<basicPsiThermo> pThermo_;
to pisoFluid.H
and
pThermo_
basicPsiThermo::New(mesh)
to pisoFluid.C in the same way the turbulence model is implemented, the pressure field isn't written correctly any more in the testcase "beamInCrossFlow" for the fsiFoam solver. It only writes the initital 0 Field for the pressure again and again. The velocity field however is written and solved. If I look up the basicThermo.H and .C file there is a definition for pressure etc.
My guess is, that there is a conflict with the namespace definitions.
Does anyone has experience with this kind of problem of compressibility implementation in FSI ?
Every suggestion and idea is welcome.
Marcel_pmd is offline   Reply With Quote
Fluid structure interaction with VOF method utilized in fluent? mxl9549 ANSYS 0 July 22, 2016 13:40
Fluid structure interaction with VOF method utilized in fluent? mxl9549 FLUENT 0 July 22, 2016 13:39
About one-way Fluid-Structure Interaction, form structure to fluid !? xq712000 ANSYS 0 July 15, 2016 09:40
Fluid Structure interaction prince_pahariaa FLUENT 3 March 19, 2013 12:16
Hypersonic Fluid Structure Interaction with openFoam? Ay82 OpenFOAM Pre-Processing 0 February 16, 2013 18:00
