Access patch geometrical variables using fvPatchVectorField |
February 26, 2019, 07:06 |
Rep Power: 8 |
Dear all,
I know that I can obtain the required info from the mesh directly, but, in any case, do you know a way to access patches and thier geometrical quantities from fvPatchVectorField ? With the following line, I can get the patch field number patchi: - const fvPatchVectorField& Up = U.boundaryField()[patchi]; Starting from Up, can I get faceCells in some way or Cf() for example? Thank you! |
February 26, 2019, 07:57 |
#2 | |
Andrew Somorjai
Rep Power: 13 |
and going back to the object itself seen here it's fvPatchFields. Code:
makeFvPatchField(fvPatchScalarField) makeFvPatchField(fvPatchVectorField)//line 587 in fvPatchField.h makeFvPatchField(fvPatchSphericalTensorField) makeFvPatchField(fvPatchSymmTensorField) makeFvPatchField(fvPatchTensorField) header for fvPatchField it seems you should be able to call patch() and snGrad(); these two caught my eye but there are many other functions and it's time consuming to trace down what they all do. |
February 26, 2019, 10:55 |
#3 | |
Vishal Achasrya
Rep Power: 14 |
You can try... const fvPatchVectorField& Up = U.boundaryField()[patchI]; const labelList faceCellList = Up.patch().faceCells(); you can also access it as a subList using labelList::subList. Hope this helps? |
February 26, 2019, 11:05 |
Rep Power: 8 |
Hello guys,
thank you for the help. Yes that workd I have also find out that this is working as well: - const fvPatch& ptch=U.boundaryField()[patchI].patch(); and then I can acces to the info using ptch.faceCells() Cheers and Thank you! |
[Commercial meshers] Fluent msh and cyclic boundary | cfdengineering | OpenFOAM Meshing & Mesh Conversion | 48 | January 25, 2013 03:28 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
chtMultiRegionFoam Tutorial | m.nichols19 | OpenFOAM | 12 | September 9, 2010 11:56 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
access to variables at interface of porous media? | Mazyar | FLUENT | 0 | October 10, 2003 14:59 |
