Obtaining the global index number of psi or source |
February 26, 2019, 08:47 |
Klaus
Rep Power: 22 |
How can I obtain the global index number of local psi or source vector values when running a case in parallel? Example: Let's assume psi has 4 values with the indices 0,1,2,3 (the matrix size would be 4x4). The values with indices 0 and 1 are allocated to process 1, the values with the indices 2 and 3 are allocated to process 2. Once allocated, the local indices become 0 and 1 on both processes. How can I obtain the global indices 0,1 and 2,3 on process 1 and 2 respectively? Klaus |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
