March 4, 2019, 21:17 |
Out of temperature range in JanafThermo
LT
Hi, everyone,
A warning message "JanafThermo<EquationOfState> out of temperature range 216.37-400, T=xxx" appears repeatedly, where xxx means a temperature over 400K while calculating a supersonic flow case. Though it dose not stop the calculation and set the highest temperature 400K, how to get rid of this message? Thanks in advance! |
March 5, 2019, 05:20 |
Olivier
hello,
take a look in your constant/thermophysicalProprties file. In the thermodynamics part, you have to set Tlow and Thigh. If your janaf polynome is still valid to 800 + K (still positive !), just set Thight higer ... regards, olivier |
March 7, 2019, 21:36 |
LT
Hi, olivierG,
In constant/thermophysicalProperties, there are no items named Tlow or Thigh, after I search the tutorials, find in a case named bubbleColumnEvaporating there exists those items as follows in constant/thermophysicalProperties.gas: H2O { specie { nMoles 1; molWeight 18.0153; } thermodynamics { Tlow 200; Thigh 3500; Tcommon 1000; highCpCoeffs (3.03399 0.00217692 -1.64073e-07 -9.7042e-11 1.68201e-14 -30004.3 4.96677); lowCpCoeffs (4.19864 -0.00203643 6.5204e-06 -5.48797e-09 1.77198e-12 -30293.7 -0.849032) } transport { As 1.67212e-06; Ts 170.672 } } There is another one for air. Seems I have to specify highCpCoeffs and lowCpCoeffs while Thigh and Tlow, how to specify those coeffs? What does Tcommon mean? Now I add gas item as follows: gas { O2 { thermodynamics { Tlow 200; Thigh 800; Tcommon 500; highCpCoeffs ( 3.03399 0.00217692 -1.64073e-07 -9.7042e-11 1.68201e-14 -30004.3 4.96677 ); lowCpCoeffs ( 4.19864 -0.00203643 6.5204e-06 -5.48797e-09 1.77198e-12 -30293.7 -0.849032 ); } } N2 { thermodynamics { Tlow 200; Thigh 800; Tcommon 500; highCpCoeffs ( 3.03399 0.00217692 -1.64073e-07 -9.7042e-11 1.68201e-14 -30004.3 4.96677 ); lowCpCoeffs ( 4.19864 -0.00203643 6.5204e-06 -5.48797e-09 1.77198e-12 -30293.7 -0.849032 ); } } } I just copy all the coeffs from the case in OF tutorials and have started the parallel computation to test the modification of thrmophysicalProperties. Any clue to the coeffs? |
March 7, 2019, 21:57 |
LT
Seems it does not work, the warning message still occurs.
O2 { thermodynamics { Tlow 200; Thigh 800; Tcommon 500; highCpCoeffs ( 3.03399 0.00217692 -1.64073e-07 -9.7042e-11 1.68201e-14 -30004.3 4.96677 ); lowCpCoeffs ( 4.19864 -0.00203643 6.5204e-06 -5.48797e-09 1.77198e-12 -30293.7 -0.849032 ); } } N2 { thermodynamics { Tlow 200; Thigh 800; Tcommon 500; highCpCoeffs ( 3.03399 0.00217692 -1.64073e-07 -9.7042e-11 1.68201e-14 -30004.3 4.96677 ); lowCpCoeffs ( 4.19864 -0.00203643 6.5204e-06 -5.48797e-09 1.77198e-12 -30293.7 -0.849032 ); } } Still the same result. Any clue? |
janafthermo, temperature range |
heat transfer coefficient value in floefd | jason kid | FloEFD, FloWorks & FloTHERM | 10 | October 16, 2016 16:55 |
DieselFoam and temperature out of janaf range | hoogland | OpenFOAM Running, Solving & CFD | 5 | January 28, 2016 12:30 |
2 region with varied properties | guserik | OpenFOAM Running, Solving & CFD | 0 | January 11, 2014 14:58 |
Free stream temperature | saharesobh | FLUENT | 1 | October 11, 2012 20:52 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
