why `cd ${0%/*} || exit 1 # Run from this directory'
Like Tree1Likes
  • 1 Post By zwlwf
Old   March 6, 2019, 21:09
Default why `cd ${0%/*} || exit 1 # Run from this directory'
Ran
random_ran is on a distinguished road
I notice that OpenFOAM use this command almost in every tutorial:
#+BEGIN_SRC sh
#+END_SRC
I usually delete this line then execute: `./Allrun'
I checkout the bash manual ( This is Edition 4.2, last updated 28
December 2010, of 'The GNU Bash Reference Manual', for 'Bash', Version
4.2. )
At the page: 3.4.2 Special Parameters
#+BEGIN_QUOTE
'0'
Expands to the name of the shell or shell script. This is set at
shell initialization. If Bash is invoked with a file of commands
(*note Shell Scripts:, '$0' is set to the name of that file. If
Bash is started with the '-c' option (*note Invoking Bash:, then
'$0' is set to the first argument after the string to be executed,
if one is present. Otherwise, it is set to the filename used to
invoke Bash, as given by argument zero.
#+END_QUOTE
I also check '-c' option on page: 6.1 Invoking Bash
#+BEGIN_QUOTE
'-c STRING'
Read and execute commands from STRING after processing the options,
then exit. Any remaining arguments are assigned to the positional
parameters, starting with '$0'.
#+END_QUOTE
Interesting, when I use the command: `bash -c ./Allrun
It works.
Why they put this line here?
Yours in CFD,
Ran
random_ran is offline   Reply With Quote
Old   March 7, 2019, 01:23
Weiliang Zhu
zwlwf is on a distinguished road
Just as the comment tells : # Run from this directory.
${i%pattern} is a bash operator, which means remove the least pattern from the end of variable i . For an example, $0 is /home/xxx/a.out, '/*' matches the /a.out, so ${0%/*} becomes /home/xxx, that is the directory of execuatable file, a.out.
kandelabr likes this.
zwlwf is offline   Reply With Quote
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 19:09
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
