Simple question on dynamic meshes
Old   April 2, 2019, 11:51
Default Simple question on dynamic meshes
celestial is on a distinguished road
I presume most users of this forum know that Foam allows modifications to the mesh topology when the relative position of solids changes ( e.g. rotating devices like fans, compressors)
But what about altering it depending on the current numerical solution in a domain ? For example, if a solution gradient is greater than a given threshold at a given cell, it would be nice if one could refine the mesh around that cell. And make it coarser when the solution gradient will later be less than the given threshold.
Best, Marc
celestial is offline   Reply With Quote
Old   April 3, 2019, 08:26
Marius Bünker
Blumenkind is on a distinguished road
It can be pretty easily done using the Mesh Refinement from dynamicFvMesh. Check out the DamBreakWithObstacle tutorial...
Blumenkind is offline   Reply With Quote
Old   April 4, 2019, 10:43
I checked that the source code for the dam break tutorial indeed includes refinement. I don't understand it enough yet to figure out if it can be adapted to some arbitrary threshold on a solution gradient as in my example, but it's a start. Thanks for the info, Marius.
Dynamic Meshing of Simple 2D Geometry harman79 FLUENT 2 January 17, 2018 06:07
Dynamic Meshes Arturo FLUENT 2 May 13, 2008 06:23
question about dynamic meshes zhhwoo FLUENT 0 August 2, 2006 22:36
Dynamic Meshes with Mixture Model cfdtoy FLUENT 3 April 13, 2004 21:16
Dynamic Meshes Cfdtoy FLUENT 2 February 6, 2004 12:14
