Setting normal gradient as BC
Like Tree1Likes
  • 1 Post By fumiya
Old   May 3, 2019, 09:27
Default Setting normal gradient as BC
Dozer_94 is on a distinguished road
I am editing icoFoam for a specific calculation in which I want to set the normal gradient of a patch as a boundary condition.
So normally scalar field 'c' would be solved using the BCs for the values of 'c', but now I would like OF to use normal gradient 'dc/dn' as BC.
I know that 'c.boundaryField()[patch].snGrad()' would return the values of the normal gradient, but I'd like it vice versa.
Anyone know if this is possible at all?
Thanks in advance,
Dozer_94 is offline   Reply With Quote
Old   May 7, 2019, 08:14
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use the fixedGradient boundary condition to set a patch normal gradient to a user-specified value.
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   May 7, 2019, 11:22
Hi Fumiya,
Thanks for your reply. I was aware that this was the way to go for the initial conditions. However, I would like OF to do this for me as a BC that changes each timestep.
To give a bit more information: I am using an external solver that calculates dc/dn from other quantities. The goal is to set this calculated dc/dn as BC for the next timestep. Therefore, I need a way (be it a provided member function or a more elaborate method) to incorporate this in the solver itself.
Thanks,
Old   May 8, 2019, 09:54
fumiya's Avatar
Fumiya Nozaki
Hi Dozer_94,
The following thread will be of help:
Updating Boundary Conditions Each Iteration
Fumiya
Gerry Kan likes this.
[Personal]
Old   May 21, 2019, 10:33
Thank you Fumiya, this was exactly what I was searching for. Seems like something I could have figured out myself, though.
solver, volscalarfield
[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Community Contributions 32 November 17, 2017 03:44
How to extract the normal pressure gradient from the momentum equation mtgoncalves OpenFOAM Programming & Development 4 September 29, 2017 10:50
Surface normal velocity BC with zero gradient tangential, cylinder c_dowd OpenFOAM Running, Solving & CFD 0 May 25, 2013 07:22
[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Community Contributions 2 January 26, 2013 02:37
normal temperature gradient on a boundary Sandrine FLUENT 0 June 10, 2009 12:29
