Incorporating pyrolysis Model in chtMultiRegionFoam
Like Tree13Likes
Old   May 7, 2019, 04:44
Default Incorporating pyrolysis Model in chtMultiRegionFoam
Archana V is on a distinguished road
I am trying to add pyrolysis model in chtMultiRegionFoam (version-6). I am able to compile the new solver. But when I run my case, following error has been obtained.
archanav@pc421-195:~/OpenFOAM/archanav-6/run/surfaceReaction1$ myChtMultiRegionFoam
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6
Exec : myChtMultiRegionFoam
Date : May 07 2019
Time : 11:01:23
Host : "pc421-195"
PID : 8019
I/O : uncollated
Case : /home/archanav/OpenFOAM/archanav-6/run/surfaceReaction1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create fluid mesh for region region2 for time = 0
Create solid mesh for region region1 for time = 0
Create solid mesh for region region3 for time = 0
*** Reading fluid mesh thermophysical properties for region region2
Adding to thermoFluid
Selecting thermodynamics package
type hePsiThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Selecting chemistryReader foamChemistryReader
elements not defined in "/home/archanav/OpenFOAM/archanav-6/run/surfaceReaction1/constant/region2/reactions"
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to hRefFluid
Adding to ghFluid
Adding to ghfFluid
Adding to turbulenceFluid
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Adding to reactionFluid
Selecting combustion model PaSR
Selecting chemistry solver
solver EulerImplicit;
method standard;
StandardChemistryModel: Number of species = 3 and reactions = 0
using integrated reaction rate
Adding to radiationFluid
Selecting radiationModel none
Adding to KFluid
Adding to dpdtFluid
Adding to fieldsFluid
Adding to QdotFluid
Adding MRF
No MRF models present
Adding fvOptions
*** Reading solid mesh thermophysical properties for region region1
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
equationOfState rhoConst;
specie specie;
elements not defined in "/home/archanav/OpenFOAM/archanav-6/run/surfaceReaction1/constant/region1/reactions"
Adding to radiations
Selecting radiationModel opaqueSolid
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
Selecting sootModel none
Adding fvOptions
Creating finite volume options from "system/fvOptions"
Selecting finite volume options model type scalarSemiImplicitSource
Source: HeatSource
- selecting all cells
- selected 3595 cell(s) with volume 0.00068306205
Adding Pyrolysis model
*** Reading solid mesh thermophysical properties for region region3
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
Adding fvOptions
Selecting pyrolysisModel reactingOneDim
Selecting region model functions
none
--> FOAM FATAL ERROR:
index -1 out of range 0 ... 8216
From function void Foam::UList<T>::checkIndex(Foam::label) const [with T = int; Foam::label = int]
in file /home/archanav/Documents/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/UListI.H at line 106.
FOAM aborting
#0 Foam:: error:: printStack(Foam:: Ostream&) at ~/Documents/OpenFOAM/OpenFOAM-6/src/OSspecific/POSIX/printStack.C:218
#1 Foam:: error:: abort() at ~/Documents/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/error.C:249
#2 Foam:: Ostream& Foam:: operator<< <Foam:: error>(Foam:: Ostream&, Foam:: errorManip<Foam:: error>) at ~/Documents/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/errorManip.H:85 (discriminator 4)
#3 Foam:: UList<int>:: checkIndex(int) const at ~/Documents/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/UListI.H:106
#4 Foam:: UList<int>:: operator[](int) const at ~/Documents/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/UListI.H:201
#5 Foam:: regionModels:: regionModel1D:: initialise() at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/regionModel/regionModel1D/regionModel1D.C:90 (discriminator 2)
#6 Foam:: regionModels:: regionModel1D:: regionModel1D(Foam:: fvMesh const&, Foam:: word const&, Foam:: word const&, Foam:: dictionary const&, bool) at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/regionModel/regionModel1D/regionModel1D.C:350
#7 Foam:: regionModels:: pyrolysisModels:: pyrolysisModel:: pyrolysisModel(Foam:: word const&, Foam:: fvMesh const&, Foam:: dictionary const&, Foam:: word const&) at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/pyrolysisModels/pyrolysisModel/pyrolysisModel.C:109
#8 Foam:: regionModels:: pyrolysisModels:: reactingOneDim:: reactingOneDim(Foam:: word const&, Foam:: fvMesh const&, Foam:: dictionary const&, Foam:: word const&) at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/pyrolysisModels/reactingOneDim/reactingOneDim.C:569
#9 Foam:: regionModels:: pyrolysisModels:: pyrolysisModel:: adddictionaryConstructorToTable<Foam:: regionModels:: pyrolysisModels:: reactingOneDim>:: New(Foam:: word const&, Foam:: fvMesh const&, Foam:: dictionary const&, Foam:: word const&) at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/pyrolysisModels/lnInclude/pyrolysisModel.H:114 (discriminator 2)
#10 Foam:: regionModels:: pyrolysisModels:: pyrolysisModel:: New(Foam:: fvMesh const&, Foam:: dictionary const&, Foam:: word const&) at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/pyrolysisModels/pyrolysisModel/pyrolysisModelNew.C:115
#11 Foam:: regionModels:: pyrolysisModels:: pyrolysisModelCollection:: pyrolysisModelCollection(Foam:: fvMesh const&) at ~/Documents/OpenFOAM/OpenFOAM-6/src/regionModels/pyrolysisModels/pyrolysisModel/pyrolysisModelCollection.C:85
#12 ? at ~/OpenFOAM/archanav-6/applications/solvers/heatTransfer/myChtMultiRegionFoam/createFields.H:14
#13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14 ? at ??:?
Aborted (core dumped)
I am simulating an annulus flow in which region 1 is a horizontal solid rod (solid reaction happens here with the fluid), region 2 is the fluid flowing in the annulus and region 3 is the outside pipe.
These modifications are done in the code
/*------------- createSolidFields.H-------------------*\
PtrList<regionModels:: pyrolysisModels:: pyrolysisModel>tpyrolysis(solidRegions.size());
forAll(solidRegions, i)
Info<< " Adding Pyrolysis model\n" << endl;
tpyrolysis.set
i,
regionModels:: pyrolysisModels:: pyrolysisModel:: New(solidRegions[i])
IOdictionary additionalControlsDict
IOobject
"additionalControls",
runTime.constant(),
solidRegions[i],
IOobject:: MUST_READ_IF_MODIFIED,
IOobject:: NO_WRITE
volScalarField Qdot
IOobject
"Qdot",
runTime.constant(),
solidRegions[i],
IOobject:: READ_IF_MODIFIED,
IOobject:: AUTO_WRITE
solidRegions[i],
dimensionedScalar("Qdot", dimEnergy/dimVolume/dimTime,0.0)
Switch solvePyrolysisRegion
additionalControlsDict.lookupOrDefault<bool>("solv ePyrolysisRegion",true)
/*------------- setSolidFields.H-------------------*\
regionModels:: pyrolysisModels:: pyrolysisModelCollection& pyrolysis = tpyrolysis[i];
in main code pyrolysis.evolve(); is added
I don't know how to tackle this problem as I am new to OpenFOAM and C++language. I would be grateful, If anyone could help me to solve this problem. Looking forward for reply.
Regards
Archana
atulkjoy and Zhiheng Wang like this.
Archana V is offline   Reply With Quote
Old   May 12, 2019, 11:42
I solved above problem.
Old   July 22, 2019, 10:52
Paulo SPS is on a distinguished road
Hi there,
I am new to openfoam and I'm trying to do something similar.
Did you manage to read the reactions into the solid region from the "reactions" dictionary or you went another route?
I managed to read a composition into the solid region using "solidReactionThermo.H" but I can't for the life of me figure out how to read the reactions, not to mention the actual reaction rates to put into an Y equation for the solid region.
Cheers
Paulo SPS is offline   Reply With Quote
Old   July 22, 2019, 21:44
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Paulo,
Hereby some hints for you to follow on.
Take a look at this blog:
http://sourceflux.de/blog/howto-writ...n-in-openfoam/
Here you can find - significant note in comment section:
Once you have figured out the dendency structure of both solvers, you should make sure that the solution algorithms used for the model implemented by both solvers fit together. For example, if fireFoam is based on a PISO/PIMPLE loop and executes bunch of models in the in-between steps of such a segregated algorithm, it would not be straightforward to couple the functionality of fireFoam with another solver that relies on fully implicit equation coupling with block matrices.
At this point you should chose the source and the target for the new combined solver. Obviously, if fireFoam is more complicated in the sense of library dependencies as well as the overall solution algorithm, then you should port the chtMultiRegionFoam into fireFoam.
Later, you can manage your pyrolysis solver in different blocks using "compressible::turbulentTemperatureCoupledBaffleMi xed" condition
Paulo SPS likes this.
Kummi is offline   Reply With Quote
Old   July 23, 2019, 00:25
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Hi how did you add pyrolysis to chtMultiRegion Foam and how did the problem was solved can you reply ??
By the way why did not you Used fireFoam ???
Zhiheng Wang is offline   Reply With Quote
Old   July 23, 2019, 00:28
Zhiheng Wang
How did you solved and what part you have modified ???
Old   July 23, 2019, 00:41
Atul Kumar
Location: National Centre for Combustion Research and Development
atulkjoy is on a distinguished road
Where was the problem ??? I have tried the same thing, This sort of problem can also be tried using fireFOAM and reactingParcelFilmFoam. Did you tried so
atulkjoy is offline   Reply With Quote
Old   July 23, 2019, 07:33
Kumaresh
In my case, I developed a solver for pyrolysis based on fireFOAM. For simulating two regions, I implemented "compressible::turbulentTemperatureCoupledBaffleMix ed" condition as stated below:
boundaryField
hotSide
type fixedValue;
value uniform 1323;
right
type symmetryPlane;
value uniform 0;
sides
type empty;
furnace_to_oven
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value uniform 293;
neighbourFieldName T;
K solidThermo;
KName none;
Keep both pyrolysis zones active.
pyrolysis
active true;
pyrolysisModel reactingOneDim;
regionName furnace;
reactingOneDimCoeffs
filmCoupled false;
radFluxName Qr;
minimumDelta 1e-8;
reactionDeltaMin 1e-8;
moveMesh false;
infoOutput true;
However, switch off the chemistry for regions where pyrolysis is not necessary.
solidChemistryModel ODECoalHeterogeneousChemistryModel<constSolidTherm oPhysics>;
gasThermoModel gasThermoPhysics;
chemistry off; //on - region2
chemistrySolver ode;
initialChemicalTimeStep 1e-07;
odeCoeffs
solver SIBS;
eps 0.05;
In addition, use topoSet command to explicitly create two zones followed by splitMeshRegions.
If above steps are followed, one can implement the multiple regions (chtMultiRegionFoam) in pyrolysis solver.
Hope it helps. Thank you ^^
Saeng Kinley and Zhiheng Wang like this.
Old   November 16, 2019, 05:29
Saeng Kinley's Avatar
Saeng-min-Kinley
Location: King Mongkut's University of Technology Thonburi (KMUTT)
Saeng Kinley is on a distinguished road
There will be a difference in solution if you create Two Regions by splitMesh and if Your create Region by extrudetoRegionMesh.
Saeng-min-Kinley.
Saeng Kinley is offline   Reply With Quote
Old   November 22, 2019, 04:15
Kumaresh
In my case, there are 2 regions "furnace" and "oven".
"Furnace" treated with heat equation only. And the "oven" involves pyrolysis. The resultant heat outflow from the furnace is introduced inside "oven" using coupled boundary condition. And for this reason to split 2 zones, I implemented "splitMeshRegions" command. Is there any other command to be used promptly?
Could you please explain me the difference in solution using both commands?
Thank you
Zhiheng Wang likes this.
Old   July 9, 2020, 09:10
Armin Alavi
ArminAlavi is on a distinguished road
hello Archana
I am struggling with a problem same to yours. I want to implement the fireFoam pyrolysis model in chtMultiRegionFoam. May I ask how did you manage to do so?
Thank you in advance
Armin
ArminAlavi is offline   Reply With Quote
Old   July 10, 2020, 01:53
Kumaresh
Hello Armin,
Kindly choose the source and the target for the new combined solver. FireFoam is more complicated in the sense of library dependencies as well as the overall solution algorithm, then you should port the chtMultiRegionFoam into fireFoam.
Above comments may clearly give you some idea. Did you got It?
Thank you ^^
ArminAlavi likes this.
Old   July 10, 2020, 03:29
Armin Alavi
hello Kummi
First of all thank you for your reply. Yes I get the general idea, but I have one more question if you will. you are right about library dependencies and complexity of the fireFoam solver. the below code is a part of fireFoam.C that solves the solid fuel part:
if(solvePyrolysisRegion)
pyrolysis.evolve();
Am I right? the rest is similar to what chtMultiRegionFoam solves for fluid part. In your opinion is it right to just add the pyrolysis region solver(libraries and needed classes included) to the chtMultiRegion Solver?
Old   July 10, 2020, 04:16
Armin Alavi
I am sorry to trouble you, but I have one more question. The pyrolysis model which OpenFOAM provides only interacts with surface films, If I am right, that is why you have to define your solid region by extrudeMesh. I want to have a volume of solid. Is there a way to make this model work on 3d arbitrary mesh?
Thank you
Armin
Old   July 10, 2020, 04:45
Kumaresh
Hello Armin,
Yes you are right. FireFOAM solver rely on pyrolysis based on the keyword pyrolysis.evolve(). It was resolved based on regionModel (based on coupled Boundary condition - using extrudetoRegionMesh) under the source file reactingOneDim. Its dependent libraries for thermo, transport and other properties are declared in thermophysicalproperties under the file names like solidChemistryModel, basicSolidThermo and so on [kindly follow the keyword "solid" and header files accordingly to understand]
Yes, you are right. In chtMultiRegionFoam solver, if I'm not wrong, solid model is resolved only with diffusion equation fvm::laplacian(kappa, T). Inclusion of source term like solid (wood, coal) heat absorption (endothermic) and exothermic heat release was found in pyrolysis solver under FireFOAM. If you look deep into the code, pyrolysis is solved based on regionModelling, whereas chtMultiRegionFoam was constructed based on fully implicit equation coupling with block matrices [solid, fluid]. So my request is, before trying to merge both solvers, be clear with the algorithms and physics of both solvers. You also need to be quite confident with OpenFOAM technics. Nothing is impossible. I haven't done it either, since its not part of my plan now. In my other work, I have partially achieved by coupling boundary condition as explained above.
Big NO. Not only interacts with surface film. You can disable/remove the surface film option as per your need. If you implement the extrudeMesh command, the solver doesn't consider the extruded part as separate body/domain because, its just extruded [like Pad option in CATIA]. To be more clear, when you do extrudeMesh command, you cant define the boundary condition for the extruded domain. Instead, if you try the command splitMeshRegions -cellZones -overwrite, you will get 2/more zones, where you can apply conditions as per your need.
Try with splitMeshRegions command if you have more than 1region, you will find a way.
fvScalarMatrix TEqn
fvm::ddt(rhoCp, T_)
- fvm::laplacian(K_, T_)
chemistrySh_ //RRs*hf (hf - heat of formation) // explicit - Endothermic reaction
Here is the pyrolysis governing equation mentioned above. It serves perfectly for 3d arbitrary mesh.
In OpenFOAM as per my knowledge, pyrolysis model is depicted with the tag "1D", due to the energy transfer from pyrolysis to combustion model normal through the surface (in one direction, so called 1D). So, the tag "1D" doesn't mean that the pyrolysis can be solved only with 1D.
Feel free to ask any query.
Thank you
Old   July 10, 2020, 08:25
Armin Alavi
Hello Kummi,
Thank you very much for your precise advice. I will look into it. Although another thing started to interest me. Do you suggest that , if I use the fireFoam solver without any changes in the code with splitMeshRegions utility it would work just fine with suitable boundary conditions implemented. If that statement is right then I have no need to merge two solvers.
Thank you very much
Armin
Old   July 10, 2020, 09:59
Kumaresh
Hello Armin,
You are welcome.
It depends on your work. In my work, 2 regions are solid, in one region I need to solve only diffusion equ, whereas the other region solves pyrolysis. By switching the chemistry properties ON/OFF, I control my code.
But if its fluid/solid blocks, then no other go, you need to merge. May I know, WHat kind of problem you are gonna approach ?
Thank you
Old   July 11, 2020, 03:22
Armin Alavi
Hello Kummi,
To be more specific, my simulation consists of two regions, a solid polymer and a fluid flow. The fluid is a hot molten metal that interacts with the polymer causing it to pyrolise. In this interaction, polymer degrades into residual gases, the residual gases are diffused into the fluid region, meanwhile the molten metal eats it's way through the polymer by pyrolysing it. From what you said about fluid/solid interaction, I think the solution is to merge the two solvers, Am I right?
Thank you
Armin
Old   July 11, 2020, 03:56
Kumaresh
Hello Armin,
The energy in the form of heat is supplied by hot molten metal in fluid state. This source of energy from fluid causes the solid polymer to pyrolise. Its perfect fluid/solid interaction as you say.
So, its not about 2 regions (like chtmultiregionFOAM).. Its all about multiphase problem with fluid/solid interaction. Did I got it right ?
Old   July 11, 2020, 04:37
Armin Alavi
Hello again
Yes you got it right about the multiphase problem + fluid/solid interaction but yet I don't understand how isn't it a 2 region problem. Is it because fields inside the solid part do not need to be solved? and the fluid/solid surface interactions are only important?
Coupling RPI wall boiling model with population balance model in Fluent softice2006 Fluent Multiphase 1 April 19, 2023 02:09
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 09:29
FireFOAM Pyrolysis Model erk070 OpenFOAM 1 September 30, 2013 10:40
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
