Adding Temperature to icoUncoupledKinematicParcelFoam
Old   May 22, 2019, 18:04
Default Adding Temperature to icoUncoupledKinematicParcelFoam
Aishwarya Krishnan
aishk is on a distinguished road
Hi!
I am trying to create a model that has a TEqn.H with the following equation:
ddt(T)+U. div(T) = laplacian(alpha.T) +heat transfer(particle-particle) +heat transfer(wall-particle)
But, the last two terms would require particle temperatures at each time step (depends on T(1st particle)-T(2nd particle)). How do I get these values? and what would the initialization look like?
Thank you!!
aishk is offline   Reply With Quote
heat transfer modelling, lagrangian openfoam, openfoam 1.5-dev
Adding temperature equation to porousSimpleFoam David_010 OpenFOAM Programming & Development 9 February 14, 2018 01:22
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 07:55
Problems adding temperature to icoFoam sur4j OpenFOAM Programming & Development 8 January 11, 2015 01:14
Adding Temperature in channelFoam dhruv OpenFOAM 10 May 5, 2012 05:40
Adding temperature equation in settlingFoam sachin OpenFOAM Running, Solving & CFD 2 March 31, 2010 03:21
