How to change a dimensionedScalar into volScalarField
Like Tree3Likes
  • 3 Post By jherb
Old   May 25, 2019, 12:05
Arrow How to change a dimensionedScalar into volScalarField
Purn Prakash
purnp2 is on a distinguished road
I am using one RAS model (Hellsten-EARSM from Furst's GIT repository) to make some changes into it.
In the transport equation maker function, I want to change a few coefficients (zeta_, beta_, and alphaD_) from its type [dimensionedScalar] to another type [volScalarField] to make it compatible with the rest of the code in its original code.
Original Code:
        volScalarField gamma( this->gamma(fMix) );
        volScalarField beta( this->beta(fMix) );
        volScalarField alphaD( this->alphaD(fMix) );
Here, this->gamma(fMix) is of the type volScalarField.
Changes I made which are producing error:
        volScalarField zeta( this->zeta_ );
        volScalarField beta( this->beta_ );
        volScalarField alphaD= this->alphaD_ ;
In the changed code, zeta_ [dimensionedScalar] replaces this->gamma(fMix) [volScalarField] and like wise in two other cases.
I am attaching changed files also:
So, how can I change its type?
Thank you for your time for reading this.
Purn
purnp2 is offline   Reply With Quote
Old   May 25, 2019, 15:51
Purn Prakash
One possible solution (which, I guess, is not correct even though it compiles and run) is as follows:
I used a formula:
    tmp<volScalarField> blend
        const volScalarField& fMix,
        const dimensionedScalar& psi
    ) const
        return fMix*(psi)/fMix;
were fMix is of type [volScalarFeild].
Is it an acceptable solution?
I am hoping for a solution where I can use any standard function of foam:: like:
typedef GeometricField<scalar, fvPatchField, volMesh> volScalarField
Old   May 30, 2019, 09:46
Joachim Herb
jherb is on a distinguished road
Have a look e.g. at https://github.com/OpenFOAM/OpenFOAM...ewtonian.C#L54
     nu_
         IOobject
             name,
             U_.time().timeName(),
             U_.db(),
             IOobject::NO_READ,
             IOobject::NO_WRITE
         U_.mesh(),
         nu0_
nu_ is a volScalarField and nu0_ a dimensioned scalar. So if you use this in a function (and not in a constructor), it should look like this (not tested):
     volScalarField nu_
         IOobject
             "name",
             U_.db(),
             IOobject::NO_READ,
             IOobject::NO_WRITE
         U_.mesh(),
         nu0_
you need the variable containing a reference to the mesh or the internal database in for the call to IOobject. (see e.g. the solver source codes or boundary conditions)
purnp2, lpz456 and wht like this.
jherb is offline   Reply With Quote
Old   May 31, 2019, 16:37
Purn Prakash
Thank you very much, sir. I'll check this code and update this reply if it works for me or not. I appreciate your help.
No matching function error: Phase change source term added to interMixingFoam wavefunction OpenFOAM Programming & Development 2 February 4, 2022 07:46
how to change boundaryType in volScalarField gaza OpenFOAM Programming & Development 6 October 20, 2017 07:35
Compressible 2D airfoil rhoSimpleFoam fatal error volScalarField none jfournier OpenFOAM Running, Solving & CFD 4 September 28, 2017 06:28
Radiation interface hinca CFX 15 January 26, 2014 17:11
converting from dimensionedScalar to volScalarField shash OpenFOAM Running, Solving & CFD 7 July 11, 2012 05:02
