reactingParcelFoam without carrier phase
Old   June 7, 2019, 16:12
Default reactingParcelFoam without carrier phase
Aishwarya Krishnan
aishk is on a distinguished road
Is it possible to remove the carrier phase completely for reactingParcelFoam and just have inert air while particle interaction causes temperature variations in the domain?
I want to try modeling something similar to heat transfer in a packed bed of particles.
Thanks
aishk is offline   Reply With Quote
Old   June 9, 2019, 05:47
raumpolizei is on a distinguished road
Hey Aishwarya,
I can only give you some ideas on how I would try to mimic your problem. From an implementation point of view it is not possible to "remove" the carrier. The particle mass and heat transfer equations include convective parts which are depending on the carrier velocity. In order to remove this you will have to set the velocity to zero. What you are then solving is a basic heat conduction equation with source terms due to the particle phase. My suggestion is to throw away the equations for U and p and to only solve the energy equation while keeping the carrier density constant. Alternatively, set the velocity to zero and remove the momentum exchange between particles and carrier.
Cheers
RP
raumpolizei is offline   Reply With Quote
heat transfer modelling, lagrangian openfoam, openfoam 1.5-dev
How to calculate carrier phase thermal conductivity in lagrangian library bijan darbari OpenFOAM Programming & Development 0 May 30, 2017 23:51
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
Three Phase flow into a reservoir... akjha Main CFD Forum 0 December 15, 2014 07:01
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
