Get distance between all cells in a parallel run |
June 12, 2019, 08:15 |
Jose Rothkegel
Rep Power: 11 |
I would like to iterate through all cells in a mesh to obtain the distance between them. When done in a serial calculation it works fine. When done in parallel it only performs the calculation for each processor. Is there a way to calculate the distance from a given cell to all the cells in a parallel run? |
iterate, openfoam, parallel |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
