Adaptive Mesh Refinement and flux(alpha.water)
Old   June 14, 2019, 01:01
Default Adaptive Mesh Refinement and flux(alpha.water)
krishna kant
kk415 is on a distinguished road
Hello All,
I am using adaptive mesh refinement for multiphase flow and I am getting the following warning. It seems I need to define flux(alpha.water) none in fvSchemes to supress this warning. But I want to know the reason why I am getting this error and can this warning effect my solution?
--> FOAM Warning :
From function Foam::autoPtr<Foam::mapPolyMesh> Foam::dynamicRefineFvMesh::refine(const labelList&)
in file dynamicRefineFvMesh/dynamicRefineFvMesh.C at line 321
Cannot find surfaceScalarField flux(alpha.water) in user-provided flux mapping table
5
rhoPhi none
phi none
ghf none
nHatf none
alphaPhi none
The flux mapping table is used to recreate the flux on newly created faces.
Either add the entry if it is a flux or use (flux(alpha.water) none) to suppress this warning.
kk415 is offline   Reply With Quote
