Inlet or outlet when flux is tangential to face |
June 19, 2019, 05:22 |
Rep Power: 9 |
The sign of the flux normal to a face is checked in the inletOutlet and outletInlet boundary conditions in order to determine whether a refValue or a refGradient should be applied. What happens when the flux is 0 (in which case there is no inlet or outlet because the local flow is parallel to the face)? Do the boundary conditions then default to either inlet or outlet or something else?
boundary conditions, inlet and outlet |
Axial flow fan incorrect pressure rise | yambanshee | OpenFOAM Running, Solving & CFD | 2 | June 25, 2020 14:05 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 15:50 |
Setting Density for Velocity Inlet Face | arkie87 | FLUENT | 0 | November 7, 2012 15:15 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
