OpenFoam 3D cases
Like Tree1Likes
Old   May 20, 2016, 12:00
Default OpenFoam 3D cases
anonymous
cute is on a distinguished road
Is there any basic tutorial available for 3D cases? The tutorial contains 2D cases, I am not aware if there is any 3D case.
I am looking basic setup for creating my own model.
Thanks.
cute is offline   Reply With Quote
Old   May 21, 2016, 18:15
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
tutorials/basic/laplacianFoam/flange looks quite 3D. What exactly you are looking for?
alexeym is offline   Reply With Quote
Old   May 21, 2016, 18:47
anonymous
Originally Posted by alexeym View Post
Thnaks alexeym for replying. I found another one but it also did not solve my problem. In tutorial case, I don't see 3D object at all, i.e expecting a sphere in the center.
I created a geometry with dimension 1 x 1 x 0.5. I initialized the bottom part with a rectangular box in center and with field value 0.2. After running blockMesh and setFields, i visualized it in paraview. I can see 3D mesh, but I don't see rectangular box in center. Instead it appears as a 2D rectangle but not a box.
Old   May 21, 2016, 19:04
Alexey Matveichev
So, do I get it right: you are quite happy with generated 3D mesh, and not satisfied with setFields results? Could you post setFieldsDict file (and maybe screenshots of your visualization, to be sure words in message and picture are the same, to avoid misunderstanding)?
Old   May 21, 2016, 19:20
anonymous
Here is setFieldsDict
| \\ / O peration | Version: v3.0+ |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues ( volVectorFieldValue U (0 0 0) volScalarFieldValue T 0);
regions ( boxToCell { box (0.04 0.04 0) (0.06 0.06 0.04) ; fieldValues ( volScalarFieldValue T 0.2) ; } );
Old   May 22, 2016, 04:58
Alexey Matveichev
Well, it is not setFields, it is the way you visualize the field. On the picture it looks like you selected "Surface" representation in paraview and then set opacity of the surface (but it still remain surface, i.e. something 2D). To look inside your mesh, you need to cut it with Clip filter (see attached screenshot for example) or use Volume representation.
Old   May 22, 2016, 12:16
anonymous
Thanks, probably this is the problem. I am new to openfoam and paraview and still learning. How can I use volume representation to visualize as 3D? Could you please write steps or point me to some tutorial?
Edit:
I was able to use clip filter as you mentioned. But it only shows shape as a slice. How can I see my whole object as 3D? Like a 3D dambreak example in youtube?
Edit:
I also managed to visualize using volume representation. Now I need to do more fine tuning and need more technique to visualize it properly.
I would like to do the following and looking for answer:
1. How to make side walls as transparent with bottom part as one color say black? Opacity make the whole box non-visible. But I need bottom part.
2. What color map should I select? My initial value is 0.2 and growing but has different values in different part of the object?
2.
Old   May 23, 2016, 01:50
Alexey Matveichev
It would be easier if you illustrate what you need. Concerning your questions:
1. Open case in paraview twice, second time you select only bottom patch in the list of parts to import and draw it with solid color.
2. Question is beyond my comprehension. You can select colormap your like and set custom range of values. Also in recent versions of paraview it can go through time steps and rescale colormap to span over whole range of values.
Old   May 23, 2016, 10:55
anonymous
Thanks alexeym for your reply.
I am simulating biomass growth in my simulations. When I change the opacity value of the grid, it also changes for biomass. It looks transparent.
1. I would like to visualize biomass growth as solid while the box invisible.
2. How can I set lighting effect to visualize it better?
3. As I am new, I used BoxToCell method to initialize my data. I don't know, how to setup initial data with semisphere at the center of bottom part.
Thanks in advance.
Old   May 24, 2016, 02:30
Alexey Matveichev
Well,
2. To understand your "better" one have to see what you have now.
3. Since setFields utility uses topoSets to select cells, you can check $FOAM_UTILITIES/mesh/manipulation/topoSet/topoSetDict for possible ways to specify selection (there is sphereToCell for example).
Old   May 26, 2016, 11:35
anonymous
How to use sphereToCell, so it produce semisphere?
Old   May 26, 2016, 16:44
Alexey Matveichev
1. Since your semi-sphere is at the bottom of domain, place center of the sphere on the edge of domain. Half of the sphere will be outside of simulation domain and you get just semi-sphere inside.
2. If you need more general solution, you have to use topoSet and setFields together. With topoSet you create hemispherical cellSet and them use cellToCell topoSet in setFieldsDict. Here is an example: imagine, you need hemisphere with centre (0 0 0.1) and 5 cm radius. You create cellSet c0 with topoSet:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name c0;
        type cellSet;
        action new;
        source sphereToCell;
        sourceInfo
            centre (0 0 0.1);
            radius 0.05;
        name c0;
        type cellSet;
        action delete;
        source boxToCell;
        sourceInfo
            box (-1 -1 -1) (1 1 0.1);
// vim: set ft=foam et sw=4 ts=4 sts=4:
First you create sphere using sphereToCell and then delete half with boxToCell. Then you can use c0 in setFieldsDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
defaultFieldValues
    volScalarFieldValue gl 0.0
regions
    cellToCell
        set c0;
        fieldValues
            volScalarFieldValue gl 1.0
As a result, you get hemisphere with gl = 1 as on the attached picture.
File Type: png Capture-d’écran-2016-05-26-à-22.37.14.png (29.5 KB, 36 views)
Old   May 27, 2016, 12:49
anonymous
Thanks for the reply. I have little problem understanding the above procedure. Please let me know, if I understand correctly.
1. Copy Cod1 in a file "toposetDict" and store it in system directory
2. Copy code 2 in setFieldsDict and store in system directory
3. Then run setFields
Am I right?
Is there any good tutorial regarding this? This might be helpful in understanding the concept.
Old   May 27, 2016, 13:10
Alexey Matveichev
Almost, before running setFields you need to run topoSet to create cell set c0. Also you need to adjust geometry in dictionaries for your case.
Unfortunately I do not know much about OpenFOAM tutorials.
Old   May 27, 2016, 13:37
anonymous
Thanks, I will try today sometime.
Old   May 27, 2016, 15:46
anonymous
I tried as you suggested, but I don't see sphere. Is there any specific filtersI need to apply. I visualized for t=0, loaded into paraview, applied clip filter but don't see anything.
My box dimension is 1 x 1 x 0.5 m^3 with
blocks ( hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1) );
I used in topoSetDict
actions
name c0;
type cellSet;
action new;
sourceInfo
centre (0.5 0.5 0);
radius 0.2;
name c0;
type cellSet;
action delete;
source boxToCell;
sourceInfo
box (0 0 0) (1 1 0.5);
when I ran topoSet command it produces
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
mesh not changed.
Created cellSet c0
Applying source sphereToCell
Adding cells with centre within sphere, with centre = (0.5 0.5 0) and radius = 0.2
cellSet c0 now size 0
Read set cellSet c0 with size 0
Applying source boxToCell
Removing cells with center within boxes 1((0 0 0) (1 1 0.5))
End
I don't know, what is wrong?
BTW: how do you submit code inside rectangle on this site? As you posted above.
Old   May 27, 2016, 16:41
Alexey Matveichev
Well, this one is quite obvious, as you just delete created sphere. You create sphere with centre (0.5 0.5 0) and radius 0.2, so it lies within (0.3 0.3 -0.2)-(0.7 0.7 0.2) and then you delete box (0 0 0)-(1 1 0.5), box overlaps sphere, so you deleted everything you have created during first step.
There is [CODE] tag. Marked as # in toolbar.
Old   May 27, 2016, 17:01
anonymous
Yes, I realized and figured out. Thanks for quick reply.
In my previous post, I was asking about toposet Guide. If it is available some where. Not about tutorial cases.
Sorry, my toolbar does not show any hash tag like #.
Old   May 27, 2016, 17:56
anonymous
Thanks for your help. I was able to run my application with 4 semi-spheres in the domain. As you can see in picture, they will grow and then merge at some time,i.e. outer surface merge. Now I need some post-processing:
(1) Is there any better option to visualize more clearly. I used only clip filter.
(2) I also would like to extract and visualize only the outer-surfaces of all semi-spheres as they grow. How can I do this?
I wanted to upload animation, but It could not.
sante likes this.
Old   May 29, 2016, 15:28
Alexey Matveichev
Since it is your simulation and process you know, it is YOU who decide what to do. For example...
- There is threshold filter. If your hemispheres have certain property than distinguishes them from other space, use it. The filter can be used to select cell with liquid in VOF. Sometimes I use the filter to select liquid pool cells.
- There is iso-surface filter. It can be used to visualize surfaces defined by certain value of field variable. It is used to draw liquid surface in VOF simulations (alpha = 0.5). I use it for visualization of solidification front (gl = 0.5).
Concerning your second question, as I said earlier, I do not know much about tutorials. topoSetDict supplied with sources of topoSet utility has plenty of examples.
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
OpenFoam - Vof verification with standard cases P Sharma OpenFOAM Running, Solving & CFD 4 December 1, 2014 00:25
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
OpenFOAM tests cases cfdivan OpenFOAM Installation 2 August 14, 2013 15:33
Convertation axisymmetric cases from Fluent to OpenFOAM Svensson OpenFOAM 0 April 19, 2011 06:08
