areaAverage sampledSurface - what does it do exactly?
Like Tree1Likes
  • 1 Post By einstein_zee
Old   August 22, 2019, 13:12
Default areaAverage sampledSurface - what does it do exactly?
er99 is on a distinguished road
Hi all,
I have inherited a code which includes the following sampling lines below within the controlDict file.
Does anyone know how the plane areaAverage operation works in OpenFOAM? What's the equation which describes this particular operation?
Would really appreciate your help!
Thanks in advance.
       type            surfaceRegion;
       libs ("libfieldFunctionObjects.so");
        enabled         true;
	writeControl    runTime;
	writeInterval   0.001;
        log             false;
        writeFields     false;
	writeArea       false;
        surfaceFormat   none;
        regionType      sampledSurface;
        name      Mean;
	sampledSurfaceDict
               type        plane;
	       basePoint   (0.1524 0 0);
	       normalVector (1 0 0);
          operation       areaAverage;
          fields
	     rho
er99 is offline   Reply With Quote
Old   August 23, 2019, 04:11
Hosein
einstein_zee is on a distinguished road
Hii there,
you may find it here "https://github.com/OpenFOAM/OpenFOAM-dev/blob/61c9bc2ee31289bc2a91a1fa60f075361fc8e61d/src/functionObjects/field/fieldValues/surfaceFieldValue/surfaceFieldValueTemplates.C"
it is :
            const scalarField magSf(mag(Sf));
            result = sum(magSf*values)/sum(magSf);
er99 likes this.
einstein_zee is offline   Reply With Quote
Old   August 23, 2019, 06:57
Originally Posted by einstein_zee View Post
Hii there,
it is :
Thanks for this!
area average, data, plane, sampling, surface
areaAverage sampledSurface - what does it do exactly? er99 OpenFOAM Post-Processing 1 September 5, 2019 10:54
weightedAreaAverage for sampledSurface Flou OpenFOAM Post-Processing 1 August 27, 2018 11:26
areaAverage pressure along streamwise direction canopus OpenFOAM Post-Processing 1 March 28, 2016 16:13
[swak4Foam] different values between swakExpression & faceSource areaAverage Paebin OpenFOAM Community Contributions 7 December 23, 2015 11:29
areaAverage of arbitary plane LilumDaru OpenFOAM Post-Processing 0 June 23, 2015 04:15
