Data exchange for internal field values between two different mesh |
September 25, 2019, 06:54 |
Hi OpenFOAMers,
My problem is similar to these two threads: How to get cell indices and manipulate field data runTime mapFields from fineMesh to coarseMesh I want to do data exchange for internal field values between two identical meshes with different mesh density. Each mesh has own solver. For example, solver1 gets results of velocity and sends them to solver2 for temperature calculation. And temperature is returned to solver1 for velocity calculation, the loop continues like this. Those two threads make use of the code of mapfields and implement it in solver. I'm not sure if I need to merge those two solvers as a new solver before using mapfields code in the solver. Where to the put the code in the solver? Similar work in OpenFOAM has been found in journal paper, it states that "The computations on the two meshes are fully coupled, meaning that data (temperature from macro- to meso-, and solid fraction from meso- to macroscale) is exchanged in both directions at every time step via a linear interpolation framework" I'm not sure how the author implement the data exchange, limited information provided in the paper. Thanks in advance. |
Transfering data from a Coarse mesh to a Fine mesh as initial values | amin.z | OpenFOAM Running, Solving & CFD | 1 | April 1, 2017 16:59 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 18:44 |
Mesh refinement with Field Functions - error | Dan Chambers | STAR-CCM+ | 7 | January 30, 2014 08:01 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
