User defined function file
Old   October 11, 2019, 06:04
Default User defined function file
David Andersson
sippanspojk is on a distinguished road
I want to define my own function file and I have read up on how it is done. I do have some basic problems though that I hope to get help with.
I am using pimpleFoam as solver and as I've understood I need to copy the whole source code for that solver to my $FOAM_USER_APPBIN directory, rename it, e.g. modifiedPimpleFoam, and then create my function (userFunc.C and userFunc.H files). So far so good?
My first problem is that I can't seam to locate my $FOAM_USER_APPBIN directory. OpenFOAM is not installed under my /home but under /apps/OpenFOAM-6...
When I type ls $FOAM_APPBIN all is good but when I type ls $FOAM_USER_APPBIN I don't find the folder, since it is trying to access /home/<user>/OpenFOAM/<user>
Can someone please help me out here?
/David
sippanspojk is offline   Reply With Quote
Old   October 11, 2019, 08:49
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by sippanspojk View Post
/David
You may used coded class instead, which resembles more closely the concept of an UDF. Some versions of openFOAM have them, and behaviour is different on the different forks:
here is the source code for said function object:
https://github.com/OpenFOAM/OpenFOAM...nctionObject.H
Santiago is offline   Reply With Quote
functionobjects, user
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
