October 17, 2019, 14:24 |
About Secondary Breakup model in SprayFoam
Germany
Rep Power: 7 |
Hi, Foamers,
I have a question while I am working on the secondary Breakup model. Like in TAB or KHRT model, we can add child parcel finally. however, the Child Parcel should have a certain mass,size,velocity,and quantity. mass and size have already implemented by openfoam and it is easy to calculate. THEN questions come. Q1: How to generate a certain quantity childParcel with different size and mass? in the code, it seems only one child parcel can be added to the domain finally. Q2: How to change the velocity of child parcel? in the sprayparcel.C, there is a parameter called child in the part of code called Calcbreakup , the majority parameters of childparcel is defined there. however, like the velocity of childparcel, it is just a copy of parents parcel. and it never mentioned anything about quantity of childparcel. How to fix those 2 questions? Thank you |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Droplet breakup using FLUENTT KHRT model | gauthamnarayan | FLUENT | 0 | June 30, 2016 01:51 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
The paper for the SHF breakup model | xck1986 | OpenFOAM | 0 | August 23, 2011 06:00 |
the role of the atomization model | Jay | Siemens | 2 | March 7, 2008 20:16 |
