Computation of faces and cells in prescribed dynamic mesh motion |
October 31, 2019, 09:28 |
Thomas
Rep Power: 7 |
In the context of dynamicInkJetFvMesh, the motion of every points is given explicitly, as seen in its implementation of mesh.update:
bool Foam::dynamicInkJetFvMesh::update() { scalar scalingFunction = 0.5* ( ::cos(constant::mathematical::twoPi*frequency_*time().value()) - 1.0 ); Info<< "Mesh scaling. Time = " << time().value() << " scaling: " << scalingFunction << endl; pointField newPoints = stationaryPoints_; newPoints.replace ( vector::X, stationaryPoints_.component(vector::X)* ( 1.0 + pos0 ( - (stationaryPoints_.component(vector::X)) - refPlaneX_ )*amplitude_*scalingFunction ) ); fvMesh::movePoints(newPoints); lookupObjectRef<volVectorField>("U").correctBoundaryConditions(); return true; } Moreover, I dont't understand how the method to get "mesh.phi" works. It is defined as Code:
const Foam::surfaceScalarField& Foam::fvMesh::phi() const { if (!phiPtr_) { FatalErrorInFunction << "mesh flux field does not exist, is the mesh actually moving?" << abort(FatalError); } // Set zero current time // mesh motion fluxes if the time has been incremented if (!time().subCycling() && phiPtr_->timeIndex() != time().timeIndex()) { (*phiPtr_) = dimensionedScalar(dimVolume/dimTime, Zero); } phiPtr_->setOriented(); return *phiPtr_; } Can you help me with that ? |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
