How to assign value in OpenFOAM
Old   December 19, 2019, 22:23
Default How to assign value in OpenFOAM
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
I have a problem related to assign value in OpenFOAM, the detail is as follow:
in interFoam solver, two variable alpha1 and alpha2 are defined as:
volScalarField& alpha1(mixture.alpha1());
volScalarField& alpha2(mixture.alpha2());
Now, I declare a variable with same type as:
volScalarField H
IOobject
"H",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
alpha1
to compute something.
After computation, I want to reassign value of alpha1 by H as:
alpha1 = H;
However, my assignment did not work since when I check the printed output of two files alpha1 and H, the value in same cell mesh are not identical as shown in the attachement.
Could anyone help me to explain the reason for that.
I thank you very much in advance.
ndtrong is offline   Reply With Quote
Old   December 22, 2019, 12:56
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I would expect that this is related to the topic when is the mixture updated. E.g., your alpha is referenced to the mixture class (mixture.alpha1()).
Now, if you would do the following:
alpha1 = H;
Info<< alpha1 << endl;
Info<< H << endl;
You should have both variables with the H values.
However, depending when you set this assignment, the following can happen:
alpha1 = H;
Info<< H << endl;
// Other code that is executed and the mixture is updated
some code that updates the mixture
// Now alpha1 is updated with the mixture class again
// alpha1 != H
// Even though you assigned H to alpha 1 before, it was overwritten again by the mixture class
runTime.write();
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   December 22, 2019, 22:46
Nguyen Duy Trong
Originally Posted by Tobi View Post
alpha1 = H;
Info<< H << endl;
alpha1 = H;
Info<< H << endl;
// alpha1 != H
runTime.write();
Dear Dr. Tobias
I thank you very much for your comments.
You are right at alpha1 = H and the value have same as H values.
My alpha1 value differ from H value because of update in MULES that I called after above assignment.
Kind regards,
Trong Nguyen
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 5, 2018 23:48
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
