Difference between Calc function in Kinematicparcel.C and ReactingParcel.C |
December 24, 2019, 23:06 |
Farzad Faraji
Rep Power: 7 |
Hello dear friends
What is the Difference between Calc function in Kinematicparcel.C and ReactingParcel.C? Thanks, Farzad |
December 25, 2019, 00:18 |
Yogesh Bapat
Rep Power: 15 |
ReactingParcel has more functionalities than KinematicParcel. Hence calc function includes heat transfer and phase change etc.
December 25, 2019, 08:14 |
Calcphasechange
Farzad Faraji
Rep Power: 7 |
Thanks for your reply.
I want to add calcphasechange to kinematicParcel.c. There are already a calc function in kinematicParcel in which code calls calcVelocity. I want to implement calcphasechange in kinematicParcel. Where should I call it? Inside cacl(in which we call calcvelocity) or outside of it? Thanks Farzad Farajidizaji |
December 26, 2019, 02:23 |
Yogesh Bapat
Rep Power: 15 |
You can use reactingParcel if that is more suitable to you instead of adding phase change to kinematicParcel. Regards, -Yogesh |
December 27, 2019, 20:57 |
Farzad Faraji
Rep Power: 7 |
thanks for your reply. In reactingParcelFoam and I have a problem in below function;
// Calc mass and enthalpy transfer due to phase change calcPhaseChange ( cloud, td, dt, Res, Prs, Ts, mus/rhos, d0, T0, mass0, 0, 1.0, Y_, dMassPC, Sh, Ne, NCpW, Cs ); Thanks, Farzad Farajidizaji |
