Difference between Calc function in Kinematicparcel.C and ReactingParcel.C
Like Tree2Likes
  • 1 Post By ybapat
  • 1 Post By ybapat
Old   December 24, 2019, 23:06
Default Difference between Calc function in Kinematicparcel.C and ReactingParcel.C
Farzad Faraji
farzadmech is on a distinguished road
Hello dear friends
What is the Difference between Calc function in Kinematicparcel.C and ReactingParcel.C?
Thanks,
Farzad
farzadmech is offline   Reply With Quote
Old   December 25, 2019, 00:18
Yogesh Bapat
ybapat is on a distinguished road
ReactingParcel has more functionalities than KinematicParcel. Hence calc function includes heat transfer and phase change etc.
farzadmech likes this.
ybapat is offline   Reply With Quote
Old   December 25, 2019, 08:14
Default Calcphasechange
Farzad Faraji
Thanks for your reply.
I want to add calcphasechange to kinematicParcel.c. There are already a calc function in kinematicParcel in which code calls calcVelocity. I want to implement calcphasechange in kinematicParcel. Where should I call it? Inside cacl(in which we call calcvelocity) or outside of it?
Thanks
Farzad Farajidizaji
Old   December 26, 2019, 02:23
Yogesh Bapat
You can use reactingParcel if that is more suitable to you instead of adding phase change to kinematicParcel.
Regards,
-Yogesh
Old   December 27, 2019, 20:57
Farzad Faraji
thanks for your reply. In reactingParcelFoam and I have a problem in below function;
// Calc mass and enthalpy transfer due to phase change
    calcPhaseChange
        cloud,
        td,
        dt,
        Res,
        Prs,
        Ts,
        mus/rhos,
        d0,
        T0,
        mass0,
        0,
        1.0,
        Y_,
        dMassPC,
        Sh,
        Ne,
        NCpW,
        Cs
I can not find where is Y_ is defined?
Thanks,
Farzad Farajidizaji
Regards,
-Yogesh
