January 9, 2020, 04:19 |
Updating a solver from OF211 to OF6
X
Rep Power: 7 |
Hello.
Topic: Electrohydrodynamic solver I am trying to update a functional code (originally developed on OF211) from EHDFoam to OF6 (my own code) EHDFoam . EHDFoam contains few validation cases. I am able to get similar results for charge bump relaxation case, and conducting cylinder case (both found in cases/validation_v2). However, when I run the BjorklundBreakupDrop case (using my modified updated solver on OF6) which deals with electric field interaction and fluid-fluid interface, my results are not similar as shown in the images below. (OF211 was updated to OF231 which showed similar results according to the paper [1]) I would appreciate if anyone could help me with this. [1] https://ris.utwente.nl/ws/portalfile...l_draft_v1.pdf |
May 13, 2020, 04:16 |
Bryan Hoon
Hi Mmalik,
I am also trying to create an EHD solver on OF but am fairly new to the software. I have tried running the validation cases using your code in OF6 but have ran into a string of errors when running the ./Allrun script. If it is possible, could you please share the modified case files you have used in validating your code? Thank you! |
ehdfoam, electrohydrodynamic, of211, of6, solver development |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 11:54 |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
