Implementation of Coherent Structure sgs Model for LES |
January 12, 2020, 06:13 |
Lorenzo
Rep Power: 10 |
Hello everybody,
I wanted to ask you if anyone among you, more advanced users, have never implemented the Coherent Structure Model for LES in OpenFoam (version >= 4.0) ? The model has been developed by Kobayashi (The subgrid-scale models based on coherent structures for rotating homogeneous turbulence and turbulent channel flow , 2005) . I would definetely be grateful if someone could post a template of source files if available of course, so as to have a starting template to work on, since this would be my first serious implementation of a new sgs model in Foam. Thank you very much in advance Lorenzo |
January 19, 2020, 07:32 |
Lorenzo
Rep Power: 10 |
I think I did it
November 19, 2020, 06:54 |
Farouk
Rep Power: 5 |
Hello Lorenzo,
I am implementing the Sigma SGS model by Nicoud (2011) . I think I have the code correctly implemented but I still get errors while complining. The errors are probably in how I set up my Make files. Did you hapen to find a template or reference guide for how the implementation is correctly carried out in OpenFOAM? I am using openFOAM 7. Would appreciate your feed back. Thank You, Farouk |
October 28, 2022, 04:27 |
Rep Power: 8 |
Dear Lorenzo,
It's been a long time, but I'd like to ask if you implemented the Sigma SGS model and tested well. If possible, whether I can get the source code, I am very interested in testing this model. |
Wall damping function in Fluent using LES with standard smagorinsky sgs model (Cs=1) | lxlylzl | FLUENT | 4 | October 13, 2018 18:35 |
dynLagrangian SGS model implementation | gggiulio | OpenFOAM Running, Solving & CFD | 8 | November 15, 2016 06:23 |
Problem with implementation LES Clark model | Lorenzo92 | OpenFOAM Programming & Development | 1 | October 18, 2016 16:55 |
Virtual inheritance problem while adding public member function to LES SGS Model | konneym | OpenFOAM Programming & Development | 4 | November 4, 2013 11:37 |
implementation of Spalart-Allmaras Turbulence Model | zhengjg | Main CFD Forum | 0 | July 24, 2013 03:43 |
