Unknown functionObject forces
Old   January 23, 2020, 08:52
Default Unknown functionObject forces
David Andersson
sippanspojk is on a distinguished road
I have for a while been working on my own functionObject (FO). I initially made a copy of the "forces" FO to my USER directory and adapted it to my needs. However, when I now try to include the old "forces" FO OpenFOAM doesn't recognize that, even though if the original files are untouched.
Does anyone know how to solve this problem?
Thanks,
David
sippanspojk is offline   Reply With Quote
Old   January 25, 2020, 06:10
Michael Alletto
mAlletto will become famous soon enough
did you overwrite the typeName in your new function object or left it the same?
 //- Runtime type information
     TypeName("forces");
If you did not change the type name this may be the reason the original function object is not recognized
mAlletto is offline   Reply With Quote
Old   January 27, 2020, 03:52
David Andersson
Hi Michael, thank you for your reply!
I found the problem on my own. In the Make/files I had change the directory to which I compile to to "FOAM_USER_LIBBIN" but I had forgotten to change the file name so I was overwriting the libforces with my new file. When I changed that I could use the original forces function again.
/David
functionobject, openfoam-6
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
Thermal Comfort Simulation in STAR CCM+ anupmu STAR-CCM+ 1 February 27, 2013 14:25
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
