New solver with turbulent scalar transport+LES model |
February 19, 2021, 14:25 |
Syavash Asgari
Rep Power: 18 |
Dear All,
I have developed a customized solver, STDPimpleFoam (Scalar Turbulent Diffusion pimpleFoam). It can solve an additional equation for a passive scalar. This is not something new by itself. However, I also developed an accompanying LES model, based on the dynamic Smagorinsky model, but with the ability to calculate the turbulent Schmidt number relying on the approach proposed by Lilly (1992). It is where things get interesting, the calculation of turbulent Schmidt number happens through a dynamic procedure, similar to what was employed in the dynamic Smagorinsky model for turbulent viscosity. I hope people will find it useful, as a proper implementation of scalar turbulent diffusion in OpenFOAM was lacking. The advantage of the developed LES model is that it does not demand modifying the turbulence models base classes (turbulenceModel, LESModel, etc...). So it should be easy to extrapolate the idea for developing other similar approaches. I have included a test case. Cheers. Last edited by syavash; March 7, 2021 at 08:55. |
February 20, 2021, 11:01 |
Herpes Free Engineer
Rep Power: 12 |
Thanks a lot for this contribution!
Could you please, if possible, further explain your remarks regarding the lack of `a proper implementation of scalar turbulent diffusion in OpenFOAM`, and/or could you please indicate/share some links involving already existing discussions/explanations?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 20, 2021, 11:12 |
#3 | |
Syavash Asgari
Rep Power: 18 |
Improved implementation of dynamic Smagorinsky If you follow it carefully, you will know about the SGS diffusivity that should be included in LES of passive/active scalar transport equations. Regards, syavash |
February 20, 2021, 12:30 |
Rep Power: 12 |
Thank you very much - just bear in mind that if we carefully examine the fundamentals and implementations, there are considerable number of other discrepancies, e.g. wrong filter size implementation - yet luckily, somewhat they don't manifest themselves badly in practice.
February 20, 2021, 14:34 |
Syavash Asgari
Rep Power: 18 |
In that case, we should not go for any development such as the dynamic Smagorinsky itself, or other recent contributions! In fact your argument would mean to stick to what is offered by developers.
If you don't find the models/libraries shared by other people fitting your needs, simply pass by! |
February 20, 2021, 14:47 |
Rep Power: 12 |
No, I just meant we - as the community- need to work more to get rid of these discrepancies by hinting there are many of them and very fundamental ones indeed - but we got lucky so far I mentioned. Not even remotely related to what was suggested by yourself, I'm afraid.
I don't accept and reject your interpretation of my remark. I was grateful and chilled out. Thanks for your contribution - highly appreciated. Keep up good work.
March 5, 2021, 03:23 |
Problem is already discussed in Length...
#7 | |
Santiago Lopez Castano
Rep Power: 15 |
https://www.mdpi.com/2311-5521/4/3/171 The biggest problem with LES and OpenFOAMers is this misconception of "Implicit Filtering". For some reason OpenFOAMers are led to believe that OpenFOAM somehow "filters" implicitely your solutions, instead of acknowledging is a property of integrating fields in FVM. By putting your fields on the centroid you admit the mean value theorem (MVT) as valid which, when written on paper, is just an average. Schumman (1973?) made thi statement explicitely for FVM. Jordan (1990?) extended this idea for curvilinear FDM. And the guys doing ILES just take it for granted... There are other authors working on evaluating the potential of OpenFOAM for industrial LES: E. M. Komen has worked a lot on that recently, is worth a look. He's one of the few who actually studies LES in OpenFOAM. The dynamic (and Lagrangian) Smagorinsky models implemented in OF so far are mathematically INCONSISTENT. Plus, the only valid test filter for dynamic models is the anisotropic (I demonstrate that in my article) with appropriate coefficients. If someone is interested (genuinely, in the sense of doing further research) please contact me directly and I can share the code. I don't want someone else claiming authorship of my work in "Scientia Iranica" or any other funky Journal in the tropics/china (yes, it has happened to me already). @Ehsan: your citation is not entirely correct (Moin et al 1991). Although the equations look "the same" conceptually they are very different, due to Favre. Cite more recent work: Piomelli et al., Sarkar et al., Armenio & Sarkar, Armenio & Piomelli, or Lopez et al. Last edited by Santiago; March 5, 2021 at 07:19. |
March 7, 2021, 08:29 |
#8 | |
Syavash Asgari
Rep Power: 18 |
P.S. I understand you suffered plagiarism, but I think it is not appropriate to include the journal names that point out the associated nation. It would create some unwanted attitudes towards the general scientific community, which I believe was not your true intention. Last edited by syavash; March 7, 2021 at 11:10. |
March 7, 2021, 13:41 |
#9 | |
Rep Power: 15 |
P.S.: Don't be condescending, I know which my intentions are when I speak, I say what I mean and I mean what I say! I don't have any hidden agendas against Iran, India, or China, I could care less either way. But that most predatory Editorials are located there, and that a good percentage of "less-than-rigorous" research is produced in those journals, there, well, is beyond reasonable doubt, Is it not? And if by "unwanted attitutes" you mean to be honest about something THAT DOES HAPPEN, then I stand by what I said, regardless of whether it may offend someone. |
March 7, 2021, 15:05 |
#10 | |
Syavash Asgari
Rep Power: 18 |
Averaging is not something new IMO. Many turbulence models in OpenFOAM differs from the original form, undergoing minor or major modifications. Yet, they are named similarly the same as the original model. I think that your claim regarding the reviewers/editors cannot be generalized. I had papers rejected by some reviewers from different places for no good reason, but I wouldn't go as far to publicly judge their ethics. |
May 12, 2022, 11:33 |
#11 | |
Tian Jin
Rep Power: 5 |
Dear syavash,
Thanks for sharing your code. I want to use the LES dynamic Smagorinsky model for eddy viscosity calculation and eddy diffusion calculation. I think your SDSM file is to do that, right? In which you added the turbulent Schmidt number calculation based on the basic LES dynamic Smagorinsky model (which is only for the eddy viscosity model). There is no problem when compiling the SDSM model. The problem is that when I test that model with your attached folder named scalarPitzDaily: --> FOAM FATAL ERROR: request for volScalarField S from objectRegistry region0 failed available objects of type volScalarField are 10 ( invScSgs nut average(interpolate(magSqr((sqr(delta)*((surfaceSu m((magSf*interpolate((mag(dev(symm(grad(U))))*dev( symm(grad(U)))))))|surfaceSum(magSf))-((4*mag((surfaceSum((magSf*interpolate(dev(symm(gr ad(U))))))|surfaceSum(magSf))))*(surfaceSum((magSf *interpolate(dev(symm(grad(U))))))|surfaceSum(magS f)))))))) Cs mag(dev(symm(grad(U)))) k mag((surfaceSum((magSf*interpolate(dev(symm(grad(U ))))))|surfaceSum(magSf))) nu delta p ) Do you have any idea about why do I make mistake? Look forward to your reply. Thanks in advance! Quote:
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Creating a transient .case file | scro1022 | EnSight | 0 | November 27, 2020 10:11 |
[General] Problem with reading in multiple grouped Ensight .case files into paraview | scro1022 | ParaView | 0 | November 27, 2020 08:00 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
