A new population balance equation solver for OpenFOAM |
February 8, 2020, 23:00 |
Dongyue Li
Rep Power: 17 |
Dear Foamers,
Multiphase system can be simulated by the Eulerian-Eulerian (E-E) method and Eulerian-Lagrangian (E-L) method. The drawback of the traditional two-fluid method is that only one velocity can be employed for both phases (although a multi-fluid method can be constructed). Another promising method is to use Eulerian method for the continuous phase and a generalized population balance equation (GPBE) for the dispersed phase. The GPBE should be solved numerically by existing method, such as the quadrature-based moments method (QBMM). Therefore, we call this method as E-QBMM, although strictly speaking it is based on Euler framework. Recently, we implemented such solver in OpenFOAM and make it open-sourced [1]. This solver was also validated by several gas-liquid test cases [2]. On the other hand, I am very interested into the algorithm. Therefore, I wrote it down and hope it can help others to understand the theory of QBMM [3]. All equations can be found there. I also would like to share some other interesting works, because the QBMM algorithm was extensively investigated/developed by the research group in Iowa State University, Ecole Polytechnique and others. For example, Alberto Passalacqua also developed his own PBM solver: OpenQBMM [4]. He also started a forum for QBMM users, which looks quite professional..http://openqbmm.freeforums.net/ [1] twoWayGPBEFoam: An open-source Eulerian QBMM solver for monokinetic bubbly flows: https://www.sciencedirect.com/scienc...10465519303728 [2] Comparison of Eulerian QBMM and classical Eulerian–Eulerian method for the simulation of polydisperse bubbly flows: https://aiche.onlinelibrary.wiley.co...1002/aic.16732 [3] Quadrature-based moment methods for the population balance equation: an algorithm review https://www.jianguoyun.com/p/DQwBtyMQ9s3ZBhjDrKYC [4] https://github.com/OpenQBMM
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html Last edited by sharonyue; February 8, 2020 at 23:18. Reason: typo |
February 9, 2020, 11:34 |
Herpes Free Engineer
Rep Power: 12 |
Thank you sharonyue,
I think OpenQBMM is now part of OpenFOAM-v1912 as a submodule. Does your code come as a submodule of OpenFOAM as well? Is it inside OpenQBMM? Or do we need to compile it separately?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 9, 2020, 21:48 |
Dongyue Li
Rep Power: 17 |
Hello Herpes,
Our code is not based on OpenQBMM. We implemented it from scratch and it should be compiled separately. I mentioned OpenQBMM is because 1) all of our algorithm belongs to QBMM. 2) I admire their effort to make it open source as well.
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
April 19, 2020, 06:23 |
Masoud Kahnooji
Rep Power: 8 |
Hi Sharonyue
Thank you for your information. What is the advantage of E-QBMM methods in comparison with two-phase euler-euler method (multi-fluid method) like twophaseeulerfoam? |
August 28, 2020, 10:12 |
Population balance in Openfoam 4.1
sujata
Rep Power: 6 |
I am a new user of Openfoam and currently using reactingmultiphaseEulerfoam 4.1. I want to add Population Balance. How can I do that? Any lead would be appreciated.
July 4, 2021, 03:48 |
Muhammad Ahyar
Rep Power: 6 |
I have the same plan for my project, have you found out how to set up a case with Population Balance into the openfoam case? thanks in advance
November 25, 2021, 20:10 |
#7 | |
Dongyue Li
Rep Power: 17 |
Hello there, sorry for my late reply. The latest OpenFOAM provides a sectional method. U can have a look.
November 25, 2021, 20:13 |
Dongyue Li
Rep Power: 17 |
We also implemented the QBMM for gas-particle flow, please see the following link:
https://authors.elsevier.com/c/1e8bP7QGmEkfF [Implementation of CHyQMOM in OpenFOAM for the simulation of non-equilibrium gas-particle flows under one-way and two-way coupling]
November 26, 2021, 06:59 |
#9 | |
Mark Olesen
Rep Power: 40 |
How much overlap would this have with OpenQBMM? Where possible it would make sense to combine efforts. |
January 4, 2022, 00:50 |
plotting the population of bubbles
#10 | |
Muhammad Ahyar
Rep Power: 6 |
some sources said that to plot the population i can use the NDF plot but i have no idea to do it with openfoam output data |
January 24, 2022, 06:53 |
#11 | |
Santiago Lopez Castano
Rep Power: 15 |
January 26, 2022, 02:52 |
Regarding the solver OF version compatibility
#12 | |
Akshay
Rep Power: 6 |
Can the twoWayGPBEfoam be compiled in open foam version 9? is it for openfoam.org or openfoam.com software? |
February 2, 2022, 07:23 |
#13 | |
Akshay
Rep Power: 6 |
I am getting an error when I tried to complile the code in OpenFoam v7. In file included from oneWayGPBEFoam.C:64:0: pEqn.H: In function ‘int main(int, char**)’: pEqn.H:29:21: error: ‘class Foam::fvMesh’ has no member named ‘solver’; did you mean ‘solvers_’? pEqn.solve(mesh.solver(p.select(piso.finalInnerIte r()))); ^~~~~~ solvers_ /opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/oneWayGPBEFoam.o' failed make[1]: *** [Make/linux64GccDPInt32Opt/oneWayGPBEFoam.o] Error 1 make[1]: Leaving directory '/mnt/d/solver/twoWayGPBEFoam/solvers/oneWayGPBEFoam' /opt/openfoam7/wmake/makefiles/apps:39: recipe for target 'oneWayGPBEFoam' failed make: *** [oneWayGPBEFoam] Error 2 I tried to compile this in /mnt/d/customsolver Was this the issue? Should I take this folder in the solver directory and then run ./Allwmake |
February 2, 2022, 11:36 |
Problem Sorted
#14 | |
Akshay
Rep Power: 6 |
suGWFoam: Richards equation solver for porous media flows | liu | OpenFOAM Announcements from Other Sources | 4 | February 10, 2021 15:14 |
Poisson equation in custom solver diverges for large boundary values | babakflame | OpenFOAM Running, Solving & CFD | 2 | May 23, 2017 20:11 |
Population Balance Equation in OpenFOAM | Amjad Asad | OpenFOAM Programming & Development | 0 | January 19, 2016 05:14 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Population Balance Theory | student | Main CFD Forum | 2 | August 10, 2008 04:12 |
