Access cell values in codeStream
Like Tree1Likes
  • 1 Post By SHUBHAM9595
Old   February 24, 2020, 03:51
Default Access cell values in codeStream
Tom Gegenbauer
gomz is on a distinguished road
I am Tom, new to CFD/OpenFOAM and very happy about this Forum, which already helped me. Thank you all!
I have a question which will be pretty simple, but I can't find a solution here or in the documentation. It is about codeStream.
I use the rhoSimpleFoam/squareBend tutorial with rhoSimpleFoam. I set the longer path as heatWalls and I want to try some alphatWall calculations.
So what I want to do is using a different calculation for alpha on a specific patchType. For this, I have a formula and I want to implement this via codeStream. This works with a set constant (e.g. alpha = 0.05).
The next step is to use the cell pressure. For this I found out, that I can access these values with
U.boundaryField()[patchi].patchInternalField()
whereas patchi is found by
const label patchi = mesh.boundaryMesh().findPatchID("bottom")
or
const scalarField& UCells = U.internalField();
forAll(UCells,CellI)
UCells[CellI];
My problem is, that I don't know how the cells, vectors etc. in OpenFOAM are handled. I want to use the cell average pressure to calculate the alphatWall. But since this is just at the wall, I don't know how to express that - or if using codeStream in 0/alphat is even the right thing to do. I can express my Solution in comments, maybe someone can help me translate this to code.
// some constants & pre-calculations needed for formula
f_d = 0.5;  // just example
f_w = 0.73*f_d;
// the example formula is: alphat = (p^f_w)*(f_d^0.1)
// from here on, I am not sure. Therefore I write in comments.
// There should be a loop over all boundary (wall) cells, but I don't know
// how to achieve this (wallCells/cellID etc.)
forAll(wallCells, cellID)
   // I have to read the value of p out of the iterated cell
    p_t = p.boundaryField()[patchi].patchInternalField() ?
   // Thats the whole patch, doesnt make sense to me.
   // Then I can calculate alpha
   alphat = pow(p_t,f_w)*pow(f_d,0.1)
I hope my problem is understandable and somebody can help me. If there is additional information material I am also interested. Thank you in advance!
Best regards
Tom
Source from access velocity code:
Access to the velocity at boundary cells
gomz is offline   Reply With Quote
Old   March 11, 2020, 11:07
MNM
SHUBHAM9595 is on a distinguished road
Hey Tom,
You are almost there. You just have to initialize the field (in your case Pressure) specifically for your patch.
const fvMesh& mesh = refCast<const fvMesh>(d.db());
const label id = mesh.boundary().findPatchID("your_patch");
const fvPatch& patch = mesh.boundary()[id];
f_d = 0.5;
f_w = 0.73*f_d;
scalarField ptemp(patch.size(), scalar(0));
scalarField alphat(patch.size(), scalar(0));
forAll(alpha[i], i)
 ptemp[i] = p[i];
 alphat[i] = scalar(pow(ptemp[i],f_w)*pow(f_d,0.1));
For additional info, you can refer the link below.
http://wiki.openfoam.com/Programming1
saeed jamshidi likes this.
SHUBHAM9595 is offline   Reply With Quote
Old   April 27, 2022, 04:30
Eric Segalerba
EricS is on a distinguished road
Hi!
I'm facing a similar problem: I'm trying to get the average pressure value on a patch. So far I wrote the following:
    throat
    type            flowRateOutletVelocity;
    volumetricFlowRate     #codeStream
            codeInclude
                #include "fvCFD.H"
            codeOptions
                -I$(LIB_SRC)/finiteVolume/lnInclude \
                -I$(LIB_SRC)/meshTools/lnInclude
            //libs needed to visualize BC in paraview
            codeLibs
            -lmeshTools \
            -lfiniteVolume
            code
        /* CYCLE EXPLAINED
        input = CPI = massFlowRate * deltaP
        1. massFlowRate = CPI / deltaP;
        2. compute first timestep with the massFlowRate just calculated;
        3. compute deltaP (which is deltaP = p_amb - p_throat = 0 - p_throat = -p_throat);
        4. correct massFlowRate with the new value of p_throat;
        5. keep iterating...
            massFlowRate^(i+1) = - CPI / p_throat^(i)
                const IOdictionary& d = static_cast<const IOdictionary&>
                    dict.parent().parent()
                const label id = mesh.boundary().findPatchID("throat");
                vectorField U(patch.size(), vector(0, 0, 0));            // initialization of the vector field
        const CPI = xxx;                        // Power Input in Watt
                const surfaceVectorField& p = patch().lookupObject("p");    // get throat's pressure
        const massFlowRate = -CPI/average(p);                // compute corresponding massFlowRate
                writeEntry(os,"", massFlowRate);
    value            uniform (0 0 0);
The idea is to get the average pressure of the "throat" patch then use that value to compute a massFlowRate to correct the value step by step.
The problem is that I keep facing errors that are surely caused by errors in my code but I'm not able to fix it properly, do you have any guess on how to repair it?
Thank you!
EricS is offline   Reply With Quote
codestream, openfoam
Access volume field values at wall-adjacent cell centres TsinghuaBoiler OpenFOAM Programming & Development 0 May 5, 2017 18:52
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Retrieving boundary patch values adjacent to a given cell brooksmoses OpenFOAM Post-Processing 2 December 8, 2008 10:00
Warning 097- AB Siemens 6 November 15, 2004 04:41
node based or cell centered Ts values acboge FLUENT 0 February 6, 2004 06:41
