Duplicate library entries when running a solver with custom library |
May 8, 2020, 08:02 |
Franco Marra
Rep Power: 17 |
Dear Foamers,
I am trying to implement some new methods in the chemistryModel library with the current OpenFOAM version 7. I followed basically the indications given in the thread named “Include my own library in sprayFOAM”. So I copied the original in the Code:
OpenFOAM/user-7/src/thermophisicalModels/chemistryModel_extended Code:
OpenFOAM/user-7/applications/solver/chemFoamExt Then I would use this new library with the reactingFoam solver and so I discovered that it depends on the combustionModels library that in turn depends on chemistryModel. Therefore, I duplicated the combustionModels library into directory: Code:
OpenFOAM/user-7/src/combustionModels_extended Code:
OpenFOAM/user-7/applications/solver/reactingFoamExt Now, what I get when I run the new reactingFoamExt solver is a long list of warnings like the following: Code:
#0 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x3e) [0x7f47b750f1ae] #1 /home/marra/OpenFOAM/marra-7/platforms/linux64GccDPInt32Opt/lib/libchemistryModel_extended.so(_ZN4Foam24chemistryReductionMethodINS_17psiReactionThermoENS_14constTransportINS_7species6thermoINS_12hConstThermoINS_24incompressiblePerfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEE31adddictionaryConstructorToTableINS_25chemistryReductionMethods3DRGIS1_SC_EEEC1ERKNS_4wordE+0xfb) [0x7f47b85acc8b] #2 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so(+0x56117e) [0x7f47b0a3b17e] #3 /lib64/ld-linux-x86-64.so.2(+0x10733) [0x7f47be210733] #4 /lib64/ld-linux-x86-64.so.2(+0x151ff) [0x7f47be2151ff] #5 /lib/x86_64-linux-gnu/libc.so.6(_dl_catch_exception+0x6f) [0x7f47b5f372df] #6 /lib64/ld-linux-x86-64.so.2(+0x147ca) [0x7f47be2147ca] #7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf96) [0x7f47b6b20f96] #8 /lib/x86_64-linux-gnu/libc.so.6(_dl_catch_exception+0x6f) [0x7f47b5f372df] #9 /lib/x86_64-linux-gnu/libc.so.6(_dl_catch_error+0x2f) [0x7f47b5f3736f] #10 /lib/x86_64-linux-gnu/libdl.so.2(+0x1735) [0x7f47b6b21735] #11 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x71) [0x7f47b6b21051] #12 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x2e) [0x7f47b7508cce] #13 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x13e) [0x7f47b719961e] #14 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openIPNS_9HashTableIPFNS_7autoPtrINS_14functionObjectEEERKNS_4wordERKNS_4TimeERKNS_10dictionaryEES6_NS_6string4hashEEEEEbSE_S8_RKT_+0x175) [0x7f47b71a6fa5] #15 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam14functionObject3NewERKNS_4wordERKNS_4TimeERKNS_10dictionaryE+0x579) [0x7f47b71a6089] #16 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeControlC1ERKNS_4wordERKNS_4TimeERKNS_10dictionaryE+0x236) [0x7f47b71b8306] #17 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList4readEv+0x786) [0x7f47b71a8f36] #18 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList11setTimeStepEv+0x2f5) [0x7f47b71a9845] #19 /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4Time9setDeltaTEd+0x35) [0x7f47b71bb2c5] #20 reactingFoamExt(+0x3245c) [0x7f47be83245c] #21 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f47b5df1b97] #22 reactingFoamExt(+0x353ca) [0x7f47be8353ca] Duplicate entry DRGEP<psiReactionThermo,const<hConst<incompressiblePerfectGas<specie>>,sensibleEnthalpy>> in runtime selection table chemistryReductionMethod But why the solver is dynamically linked to the old library that should be unknown to it? I tried to find other dependencies on the chemistryModel library into other linked libraries, but the only one depending on this seems to be the combustionModels one that I updated too. Actually, the solver works and gives the expected results, so I could ignore these warnings, but I would like to understand something more and correct my error that certainly is present somewhere. I hope somebody can help me. Included here below the copy of the Make files of the two updated library combustionModels_extended and of the solver. Thank you in advance and best regards, Franco Make/files of combustionModels_extended: Code:
combustionModel/combustionModel.C CombustionModel/CombustionModel/CombustionModels.C diffusion/diffusions.C infinitelyFastChemistry/infinitelyFastChemistrys.C PaSR/PaSRs.C EDC/EDCs.C laminar/laminars.C FSD/reactionRateFlameAreaModels/consumptionSpeed/consumptionSpeed.C FSD/reactionRateFlameAreaModels/reactionRateFlameArea/reactionRateFlameArea.C FSD/reactionRateFlameAreaModels/reactionRateFlameArea/reactionRateFlameAreaNew.C FSD/reactionRateFlameAreaModels/relaxation/relaxation.C FSD/FSDs.C zoneCombustion/zoneCombustions.C noCombustion/noCombustions.C functionObjects/Qdot/Qdot.C radiationModels/absorptionEmissionModels/greyMeanCombustion/greyMeanCombustion.C radiationModels/absorptionEmissionModels/wideBandCombustion/wideBandCombustion.C LIB = $(FOAM_USER_LIBBIN)/libcombustionModels_extended Code:
EXE_INC = \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \ -I$(LIB_USER_SRC)/thermophysicalModels/chemistryModel_extended/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \ -I$(LIB_SRC)/radiationModels/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude LIB_LIBS = \ -L$(FOAM_USER_LIBBIN) \ -lcompressibleTransportModels \ -lturbulenceModels \ -lcompressibleTurbulenceModels \ -lchemistryModel_extended \ -lradiationModels \ -lfiniteVolume \ -lmeshTools Code:
reactingFoamExt.C EXE = $(FOAM_USER_APPBIN)/reactingFoamExt Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_USER_SRC)/thermophysicalModels/chemistryModel_extended/lnInclude \ -I$(LIB_SRC)/ODE/lnInclude \ -I$(LIB_USER_SRC)/combustionModels_extended/lnInclude EXE_LIBS = \ -L$(FOAM_USER_LIBBIN) \ -lfiniteVolume \ -lfvOptions \ -lmeshTools \ -lsampling \ -lturbulenceModels \ -lcompressibleTurbulenceModels \ -lreactionThermophysicalModels \ -lspecie \ -lcompressibleTransportModels \ -lfluidThermophysicalModels \ -lchemistryModel_extended \ -lODE \ -lcombustionModels_extended |
March 19, 2021, 10:42 |
Tiziano Maffei
Rep Power: 12 |
Hi Francesco,
did you solve your issue? I am facing the same problem. If yes, could you tell me how you solved it? Thank you in advance Tiziano |
April 5, 2022, 07:07 |
Animesh Nepal
Hi Francesco, Tiziano,
Did you guys found any solution or explanation to the problem? Is it that the only solution to the problem is to rename the user libraries with a different names than it is in openfoam libraries? Thanks in advance. Animesh |
May 17, 2022, 08:37 |
#4 | |
Saleh Abuhanieh
Rep Power: 8 |
Hi, I faced this issue before. Actually, the warning is self explanatory. The problem that a certain class (DRGEP) with the same name has been defined two times: in the new developed library and in the original OpenFOAM. In my case the solution was to use the one in the OpenFOAM library. If they are not the same, for sure different name shall be used. Regards, Saleh |
compilation, custom library, library dependencies |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Error running compiled solver of fireFoam and conjugate heat transfer solver | charles4allme | OpenFOAM Running, Solving & CFD | 2 | April 26, 2019 06:58 |
Error while running new solver phaseChangeHeatDyMFoam | sabrinacarson | OpenFOAM Running, Solving & CFD | 4 | July 10, 2018 07:28 |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
