Calculating Cp, gamma and others during runtime
Old   June 5, 2020, 16:45
Default Calculating Cp, gamma and others during runtime
shock77 is on a distinguished road
I would like to calculate the specific heat capacity cp, specific heat ratio gamma and Ma number during the computation.
I have compiled a new solver based on rhoCentralFoam for this purpose.
In createFields.H I have added:
volScalarField cp
    IOobject
            "cp",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
         thermo.Cp()
volScalarField gamma
    IOobject
            "gamma",
            runTime.timeName(),
            mesh,
         thermo.gamma()
volScalarField Ma
    IOobject
            "Ma",
            runTime.timeName(),
            mesh,
         mag(U)/sqrt(thermo.gamma()*thermo.p()/thermo.rho())
I get the right values at time t = 0. Unfortunately they do not change over time, which is strange. Pressure, velocity and density do change, so the Mach Number should change aswell, but I cant see this. It works perfectly, if I use the functionObjects for the Mach Number.
I wanted to add also the total temperature and total pressure for compressible fluids to be calculated during runtime, but I would like to calculate them using the Mach Number, which is not calculated right at the moment.
Can anyone tell what I did wrong?
Kind regards,
shock77
shock77 is offline   Reply With Quote
Old   June 5, 2020, 17:28
Just found the solution to the problem.
For anyone with the same issue:
Like meantioned in this thread (How to output other properties?), it has to added, that those values are written during runtime. I have also changed IOobject::READ_IF_PRESENT to IOobject::NO_READ
So in the "while (runTime.run())" loop has to be added for example:
cp = thermo.Cp();
Old   June 5, 2020, 23:43
Default Must_read_if_modified
Sen Wang
wangsen992 is on a distinguished road
Hey,
Have you tried changing IOobject::READ_IF_PRESENT to IOobject::MUST_READ_IF_MODIFIED?
Since your coefficients are set to AUTO_WRITE, it means at end of each runTime iter those variables get written to the time directory.
While the proposed method above will achieve the same result as your method, it could be an alternative way to solve this issue (just to add to discussion). So in this way, you don't need to add
cp = thermo.Cp()
in the while loop since the backend objectRegistry should automatically update those values.
wangsen992 is offline   Reply With Quote
Old   June 8, 2020, 03:33
yes, actually I have tried it before, but without success.
I think it couldnt be updated, because it didnt change, since cp and so on
werent calculated for further timesteps.
Kind regards,
shock77
Old   July 20, 2020, 08:34
Joachim Herb
jherb is on a distinguished road
Have you tried the function object writeObjects? https://www.openfoam.com/documentati...teObjects.html
You could try either Cp or thermo.Cp and look if you get the fields written to the time folders (depending also on the writeInterval settings)
jherb is offline   Reply With Quote
Old   July 20, 2020, 09:58
I actually haven't tried that, since it worked like I have described it above.
But I think it is a good idea and when I have to do sth similar, I will try that too!
Kind regards,
shock77
Old   July 22, 2020, 17:58
Joachim Herb
Today, OpenFOAM 8 has been released. It includes two improvements, which might also be helpful in this regard:
objectRegistry: Added support for optionally caching temporary objects
https://github.com/OpenFOAM/OpenFOAM...9dc79ea4ba08ea
objectRegistry: Corrected caching of registered temporary objects
https://github.com/OpenFOAM/OpenFOAM...53fc652ead5395
