Where is the velocity flux phi initialised in Openfoam? |
June 8, 2020, 06:41 |
hari
At very beginning of the simulation, where is phi calculated /initialised?
I am aware that phi is calculated according to, phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rUA, U, phi); But at the very beginning of the simulation we have to form Ueqn using phi, unfortunately we don't have rUA at the beginning of simulation. So I am curious to know how phi is initialised? |
June 8, 2020, 07:25 |
Michael Alletto
Rep Power: 15 |
June 10, 2020, 04:26 |
#3 | |
alexander thierfelder
Rep Power: 6 |
I think this question occures very often and has been answered several times. Just use the search function. Never the less I give you some additional advice, look into createField files of the solver source code for example in icoFoam: /applications/solvers/incompressible/icoFoam Code:
Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); #include "createPhi.H" Code:
Global createPhi Description Creates and initialises the relative face-flux field phi. \*---------------------------------------------------------------------------*/ // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "Reading/calculating face flux field phi\n" << endl; surfaceScalarField phi ( IOobject ( "phi", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), fvc::flux(U) ); // ************************************************************************* // On the other hand there are also solvers that have no: Code:
U = dimensionedVector(U.dimensions(), Zero); surfaceScalarField phi ( IOobject ( "phi", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), fvc::flux(U) ); Code:
fvc::flux(U) Code:
phi = (fvc::interpolate(U) & mesh.Sf()) I have also seen versions where the "fvc::" is not put in front like in "createPhiv.H" . I also don't know why that is.(and where/what phiv is used for) Code:
surfaceScalarField phiv ( IOobject ( "phiv", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), flux(U) ); |
icofoam, rheofoam |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
pressure and velocity in OpenFoam is smaller than Fluent | mechy | OpenFOAM | 4 | September 18, 2013 16:19 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
