time derivative of laplacian
Old   August 2, 2020, 04:46
Default time derivative of laplacian
Max
nikitin-pro is on a distinguished road
I have a function I can't implement:
\frac{\partial(c\alpha\Delta T)}{\partial t}
a -- is a constant in [m2/s], which I defined via external dictionary (lookup)
c -- is a constant in [s], which I defined via external dictionary (lookup)
T -- is temperature in [K]
Laplacian of T should yield [K/m2] and c\alpha\Delta T should yield [K], which is a scalar field. I can't understand why I can't get a time derivative from it.
I've tried
fvm::ddt(c * fvm::laplacian(a,T)), but got an error: no matching function for call to ‘Foam::GeometricField::GeometricField(Foam::tmp >)’
nikitin-pro is offline   Reply With Quote
Old   August 2, 2020, 16:06
Santiago Lopez Castano
Santiago is on a distinguished road
I've tried
Assuming that your interpretation of the term you show is correct, which i think is not, you're trying to project in time a linear system of equations (laplacian). In other words, a linear system of a linear system... What you want is:
fvm::ddt(fvc::laplacian(...
Coming to your interpretation problem, you are mixing mathematical notations. The leibniz notation (d/dt) with the vector (nabla, delta) notation for derivatives. Im betting the Delta T in the term above means "temperature difference", not "second order derivative of..."'
Santiago is offline   Reply With Quote
Old   August 2, 2020, 16:22
Max
Interesting thing:compiles OK:
volScalarField lap(c * fvc::laplacian(a,T));
fvScalarMatrix TEqn (fvm::ddt(T) - fvm::ddt(lap) - fvm::laplacian(a,T) == 0);
but solution fails with the following error:
incompatible fields for operation
[T] - [(c*laplacian(a,T))]
compilation error (no matching function for call to ‘ddt(Foam::tmp >)’):
fvScalarMatrix TEqn (fvm::ddt(T) - fvm::ddt(c * fvc::laplacian(a,T))) - fvm::laplacian(a,T) == 0);
As for notation: This is a part of modified Fourier equation:
\frac{\partial}{\partial t}(T-ca\Delta T) = a\Delta T
where a -- thermal diffusivity [m2/s]
if one set c=0 s, then will get simple heat equation
Old   August 3, 2020, 15:21
Michael Alletto
mAlletto will become famous soon enough
did you try:
fvc::ddt(c * fvc::laplacian(a,T)))
I think there is no implicit operator implement in openfaom for what you want to do
mAlletto is offline   Reply With Quote
Old   August 3, 2020, 15:35
Max
I did.. same error.
a somewhat solution is that
c * fvc::laplacian(a,fvc::ddt(T)) or c * fvc::ddt(volScalarField("lap",fvc::laplacian(a,T)) )
Both compile ok and simulation runs well, but this term doesn't affect solution at all. Seems like ca\Delta\frac{\partial T}{\partial t}=0
laplacian operator, openfoam, time derivative
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
