renumberMesh_porosity_rhoReactingBuoyantFoam_editi ng_solver
Old   August 17, 2020, 18:34
Question renumberMesh_porosity_rhoReactingBuoyantFoam_editi ng_solver
nikhil108's Avatar
Nikhil
nikhil108 is on a distinguished road
Hallo Foamers,
I want to add porous capability to rhoReactingBuoyantFoam, for that by taking rhoPorousSimpleFoam as reference, I did the respective changes in UEqn.H, pEqn.H and .C file. I tested the solver with a known case, and everything runs good. But, when I use renumberMesh and run the solver, then it throws a tmp deallocated error as follows.
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 1.2e-10
Time = 1.2e-10
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for C3H8, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for h, Initial residual = 5.23194e-05, Final residual = 1.20767e-20, No Iterations 1
min/max(T) = 293, 293
--> FOAM FATAL ERROR:
tmp<N4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEE> deallocated
    From function const T& Foam::tmp<T>::operator()() const [with T = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
    in file /opt/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/tmpI.H at line 278.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >::operator()() const in "/disk/nmittapa/FOAM_USER_APPBIN/rhoPorousBuoyantFoam"
#3  ? in "/disk/nmittapa/FOAM_USER_APPBIN/rhoPorousBuoyantFoam"
#4  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#5  ? in "/disk/nick/FOAM_USER_APPBIN/rhoPorousBuoyantFoam"
Aborted
Complete case files are attached here. It seems, I missed something when editing the solver. I have no idea, whats causing this, can someone shed some light on this please
UEqn.H
 MRF.correctBoundaryVelocity(U);
    fvVectorMatrix UEqn
        fvm::ddt(rho, U) + fvm::div(phi, U)
      + MRF.DDt(rho, U)
      + turbulence->divDevRhoReff(U)
        fvOptions(rho, U)
    UEqn.relax();
    tmp<volScalarField> trAU;
    tmp<volTensorField> trTU;
    if (pressureImplicitPorosity)
    tmp<volTensorField> tTU = tensor(I)*UEqn.A();
    pZones.addResistance(UEqn, tTU.ref());
    trTU = inv(tTU());
    trTU.ref().rename("rAU");
    fvOptions.constrain(UEqn);
    volVectorField gradp(fvc::reconstruct
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
            )*mesh.magSf()
        for (int UCorr=0; UCorr<nUCorr; UCorr++)
         U = trTU() & (UEqn.H() - gradp);
    U.correctBoundaryConditions();
    fvOptions.correct(U);
    K = 0.5*magSqr(U);
   else
   pZones.addResistance(UEqn);
        if(pimple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
            )*mesh.magSf()
        K = 0.5*magSqr(U);
        trAU = 1.0/UEqn.A();
        trAU.ref().rename("rAU");
pEqn.H
rho = thermo.rho();
const volScalarField psip0(psi*p);
volScalarField rAU(1.0/UEqn.A());
surfaceScalarField rhorAUf("rhorAUf", fvc::interpolate(rho*rAU));
tmp<volVectorField> tHbyA;
        tHbyA = constrainHbyA(trTU()&UEqn.H(), U, p);
else
        tHbyA = constrainHbyA(trAU()*UEqn.H(), U, p);
volVectorField& HbyA = tHbyA.ref();
surfaceScalarField phig(-rhorAUf*ghf*fvc::snGrad(rho)*mesh.magSf());
surfaceScalarField phiHbyA
    "phiHbyA",
        fvc::flux(rho*HbyA)
      + MRF.zeroFilter(rhorAUf*fvc::ddtCorr(rho, U, phi))
  + phig
MRF.makeRelative(fvc::interpolate(rho), phiHbyA);
constrainPressure(p_rgh, rho, U, phiHbyA, rhorAUf, MRF);
fvScalarMatrix p_rghDDtEqn
    fvc::ddt(rho) + psi*correction(fvm::ddt(p_rgh))
  + fvc::div(phiHbyA)
    fvOptions(psi, p_rgh, rho.name())
while (pimple.correctNonOrthogonal())
        tmp<fvScalarMatrix> tpEqn;
                tpEqn =
                p_rghDDtEqn
                - fvm::laplacian(rho*trTU(), p_rgh)
        else
                tpEqn =
                p_rghDDtEqn
                -fvm::laplacian(rho*trAU(), p_rgh)
fvScalarMatrix& p_rghEqn = tpEqn.ref();
p_rghEqn.solve();
        if (pimple.finalNonOrthogonalIter())
        phi = phiHbyA + p_rghEqn.flux();
        p_rgh.relax();
                U = HbyA + (trTU() & fvc::reconstruct((phig + p_rghEqn.flux())/rhorAUf));
                else
                U = HbyA + (trAU()*fvc::reconstruct((phig + p_rghEqn.flux())/rhorAUf));
        K = 0.5*magSqr(U);
p = p_rgh + rho*gh;
thermo.correctRho(psi*p - psip0);
if (thermo.dpdt())
    dpdt = fvc::ddt(p);
#include "rhoEqn.H"
#include "compressibleContinuityErrs.H"
I used tmp variables, like they are used in other solvers to operate on A(), (for explicit and implicit porosity).
Please, let me know if any other details are needed.
nikhil108 is offline   Reply With Quote
c++, deallocation, programming, renumbermesh, solver compilation
