Extract Ux, Uy, Uz of U Field
Old   October 8, 2020, 15:08
Default Extract Ux, Uy, Uz of U Field
Sebastian
aeroBassti is on a distinguished road
I'm Sebastian from Germany. I'm starting to write my one post-Pro-Solver. I modified a few other Solvers and wrote some post-Pro-Solvers with Vector-Field calculation. Now I need the Ux, Uy, Uz components for further calculation (radial velocity ,....). I know, that I could use postProcess, but that is not my aim. I found a few informations, but I'm not shure if they work with OF6.
My code (first try with Uz):
#include "fvCFD.H"
#include "fvc.H"
int main(int argc, char *argv[])
  timeSelector::addOptions();
  #include "setRootCase.H"
  #include "createTime.H"
  #include "createMesh.H"
  instantList timeDirs = timeSelector::select0(runTime, args);
 double v=0;
 forAll(mesh.C(),cell){v += mesh.V()[cell];}
  forAll(timeDirs, timeI)
        runTime.setTime(timeDirs[timeI], timeI);
        mesh.readUpdate();
        Info << "Time = " << runTime.timeName() << endl;
    IOobject U
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
    volScalarField Uz
        IOobject
            "Uz",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
    U.component(vector::Z)
    Uz.write();
Info << "Volumen:" << v <<  "m3" << endl;
Info << "finished" << endl;
    return 0;
I get the error message:
44:4: error: ‘class Foam::IOobject’ has no member named ‘component’
I hope you can help me or can give me a hint.
Best regards
aeroBassti is offline   Reply With Quote
Old   October 9, 2020, 03:04
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Looks like you might just want the components function object anyhow
https://www.openfoam.com/documentati...omponents.html
olesen is offline   Reply With Quote
Old   October 9, 2020, 05:36
Sebastian
Sry, but that doesn't help me.
Do I forgot to include a file?
Old   October 9, 2020, 10:39
Mark Olesen
If you read your code more carefully, you notice that your U is an IOobject, not a volVectorField. Hard to get the component from that.
Old   October 9, 2020, 11:06
Sebastian
Thanks a lot. It works. Sometimes it is not easy to find such small mistakes.
I wish you a nice weekend.
components
funkySetBoundaryFields - Manipulation of existing field jhertel OpenFOAM Pre-Processing 16 May 18, 2020 06:32
field read after each Time Step johanning OpenFOAM Programming & Development 1 December 29, 2019 07:59
Access to field which is evaluated at the moment Tobi OpenFOAM Programming & Development 6 April 19, 2017 13:09
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
Extract velocity field in certain time step to MATLAB spatialtime CFX 3 September 9, 2009 18:30
