how to Add the material derivative of log(T) in the constitutive equation's.
Like Tree2Likes
  • 1 Post By mAlletto
  • 1 Post By bigphil
Old   January 20, 2021, 06:15
Smile how to Add the material derivative of log(T) in the constitutive equation's.
idrees khan
idrees khan is on a distinguished road
Hi Dear's.
I'm going to Add temperature Equation to viscoelasticFluidFoam solver.
there is a material derivative term of log(T) (screenshot of the equation is attached )in the constitutive equation(I.e in this case Olroyd-B)
kindly if any one could guide me how to write that term in OldoydB.C file.
I add it like
volScalarField logT = log(T);
fvm::ddt(tau_,logT) + fvc::div(phi()*tau_,logT)
but getting error like(screenshot is also attached)
viscoelasticLaws/Oldroyd-B/Oldroyd_B.C:124:27: error: no matching function for call to ‘ddt(Foam::volSymmTensorField&, Foam::volScalarField&)’
Note:I change to fvc and fvm respectively but getting same error's.
regards
Idrees khan
File Type: jpg Screenshot from 2021-01-20 12-09-16.jpg (67.6 KB, 7 views)
File Type: png Screenshot from consitutive eqaution.png (41.1 KB, 18 views)
idrees khan is offline   Reply With Quote
Old   January 20, 2021, 11:19
Michael Alletto
mAlletto will become famous soon enough
In your code
you have a volTensorfield and a scalarField as argument to the function fvm::ddt(tau_,logT)
the error simple say that such a function does not exist. See the progammer guid what is available
idrees khan likes this.
mAlletto is offline   Reply With Quote
Old   January 21, 2021, 05:55
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
To add to mAlletto's answer:
For explicit calculation of stress (or stress rate), you should use "fvc::" (explicit) operators, not "fvm::" (implicit) operators (which probably does not make sense).
bigphil is offline   Reply With Quote
Old   January 21, 2021, 06:12
idrees khan
Originally Posted by mAlletto View Post
In your code
Dear Alletto,
Sorry I studied about what you suggest me(here is screenshot) but I'm not getting well.
kindly if you could help me.
regards
idrees khan
File Type: png Screenshot from 2021-01-21 13-08-13.png (96.0 KB, 9 views)
Old   January 21, 2021, 06:17
idrees khan
Dear Cardiff,
Sorry I try both but getting the error's (see the screenshot)
File Type: jpg Screenshot from 2021-01-21 13-15-58.jpg (43.6 KB, 4 views)
Old   January 21, 2021, 07:57
Exclamation
idrees khan
Hi Dear's
Instead of adding
fvc::ddt(tau_, logT) + fvc::div( phi()*tau_ ,log)
I add the term in tauEqn like this
tau_*fvc::ddt(logT) + tau_*fvc::div(phi(),log)
and run with "wmake libso" now it compile successfully without any error's.
Regards
idrees khan
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
how can I add more terms in different equations for chemical reactions? biker Fluent Multiphase 1 March 27, 2015 12:19
modelling Differential equations in a udf RikardMNorén Fluent UDF and Scheme Programming 2 October 1, 2013 03:36
How to add transport equations alimansouri OpenFOAM Running, Solving & CFD 6 January 12, 2009 16:20
