Specify value of surfaceVectorField
Old   January 28, 2021, 08:04
Default Specify value of surfaceVectorField
chen yu Huang
chenu is on a distinguished road
I have a problem when I specify surfaceVectorField.
I will compute flow velocity of each cell face by my own program instead of using fvc::interpolation(U). So I declare a surfaceVectorField called Uf in the createFields.H, just like velocity:
surfaceVectorField Uf
IOobject
"Uf",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENTS,
IOobject::NO_WRITE
mesh
In each time step I will assign Uf, for example
Uf[faceID].x()=x velocity I computed ,which is also applied for y and z
But while executing the program, I have this error:
free(): invalid pointer
Aborted (core dumped)
If I comment this line, then there be no problem. It looks like if I specify Uf directly, the program will free Uf twice.
My questions are:
1. How do I assign surfaceVectorField by value and
2. why Uf will be free twice? I have earlier did the same to velocity (volVectorField) but there is no problem.
I will appreciate for any advice. Thank you
chenu is offline   Reply With Quote
Old   January 31, 2021, 04:20
Michael Alletto
mAlletto will become famous soon enough
https://www.openfoam.com/documentati...8H_source.html
Maybe the way the face flux phi is created helps
mAlletto is offline   Reply With Quote
Old   February 4, 2021, 06:59
chen yu Huang
Hello, mAlletto,
Thank you for your answer. I did the same way to create my variable.
I have found the reason due to this error
How can multiple a volScalarField with a surfaceVectorField ndtrong OpenFOAM Programming & Development 2 December 12, 2019 19:48
Syncing surfaceVectorField data across processors D.R. OpenFOAM Running, Solving & CFD 0 November 2, 2016 09:05
SurfaceVectorField not recognized? Verse OpenFOAM Programming & Development 1 September 18, 2016 08:57
surfaceVectorField liuke870915 OpenFOAM Programming & Development 6 April 17, 2013 20:07
surfaceVectorField lulo OpenFOAM 0 August 15, 2011 08:17
